cruise question
Old Oct 11, 2006 | 11:41 PM
loch's Avatar
cruise question
Hey guys, my sisters 93 dually 5 speed, she was driving and cruise and speedo quit, what you thinks the most likely cause ? She asked the dealer and he said wheel sensor, uhm i didnt think we had them on 93.
Old Oct 11, 2006 | 11:47 PM
flashgordon's Avatar
we have a rear speed sensor......Ya i no u now! but it's got to be the tranny or t-case(4wd) speedo generator or a broken wire between there and the speedo!.....Maybe a fuse?
If it has the gear reducer, that could be bad or the shaft striped or broker!
Old Oct 12, 2006 | 10:06 AM
rlyons's Avatar
You might want to crawl under there and take a look, mine fell out the other day on the way to Atlanta and it was still hanging from the wires and stuck on the cross member. A lot of other people have said the same thing has happened to them.
Old Oct 13, 2006 | 10:51 PM
loch's Avatar
Anyone know of a source for the sensor ? it seems to be damaged from her broken tranny mount ?
Old Oct 14, 2006 | 03:14 AM
bigragu's Avatar
Someone point out to me where this sensor is? I thought CC issues were related to switches, servo, lack of vac, brake switch, #1 2 amp fuse or a combo of all these. I never knew about a sensor by the tranny! I, too, am trying to find out about my lost CC! Please direct!
Old Oct 14, 2006 | 09:39 AM
If your speedo is working then its not the problem.....as long as the speedo works smooth!
the speedo, generator, is located on the drivers side of the tranny, tail shaft (2 wd) or at the back of the t-case (4 wd)
there could, also be gear reducer that's bolted on to it and if it's there should be investigated while you there!
You will recognize the the sensor cause it will have to 2 wires cumming out of it!
Old Oct 14, 2006 | 02:18 PM
loch's Avatar
Yea what he said
trophystock
Jul 12, 2006 09:27 AM
trophystock
Jul 6, 2006 06:28 PM
nailhead
Apr 4, 2006 10:44 PM
Goodys1ton
Aug 28, 2005 01:25 PM
dieselcrazy
Apr 7, 2003 09:36 PM
