Crank sensor gap?
Old Mar 6, 2005 | 07:21 PM
Mr. Jimmy's Avatar
Crank sensor gap?
Can someone tell me if there is an air gap setting for the crank sensor on a 93 and also what the torque specs are for the crank pulley bolts? I have a factory manual on CD but I can't get it to work. I knew this would happen sooner or later, so much for technology.I sure like the hard copies better!
Old Mar 6, 2005 | 07:27 PM
SteamDave's Avatar
I believe the gap for the crank sensor is 0.050 in. and according to my FSM the vibration dampener bolt torque is 92 ft. lbs.
Old Mar 6, 2005 | 07:28 PM
Make sure you set the gap with a brass feeler (or a matchbook cover).
Old Mar 6, 2005 | 07:40 PM
SteamDave's Avatar
Wanna, you beat me to it! wanted to look up the spec to make sure, took me alittle to find it in the FSM
Old Mar 6, 2005 | 07:55 PM
Mr. Jimmy's Avatar
Thanks for the answers. Will steel feeler gauges affect the crank sensor? I finally got my cd manual working and found the torqe spec on the crank pulley but still haven't found the crank sensor gap, where is this located? Seems this 1st G forum is a little more friendly when questions are asked. When posting questions about my truck on the 3G forum some seem to think that you're trying to pick the trucks apart, maybe I should sell it and try to find a 1st G!I truly beleive they were built better.
Old Mar 6, 2005 | 07:58 PM
Steel feeler will mess up the sensor supposedly. The gap should be set between the sensor and the crank damper, make sure you are well away from a notch because the damper kinda tapers into them.
Old Mar 6, 2005 | 08:00 PM
SteamDave's Avatar
In my printed version the 'engine speed sensor' info is in the fuel system section
(section 14 pg.109) and yes steel feelers will affect the sensor - it's magnetic, like the electronic ignition on the older gassers
Boy Wanna you can type way faster than I can
sjester
May 10, 2007 05:03 PM
Gabe32
16
Feb 22, 2007 06:37 PM
BC847
Dec 1, 2006 11:33 PM
Mark Thomas
Sep 15, 2004 09:02 AM
thumper 549
19
Oct 2, 2003 05:38 PM
