Conflicting injector info
Old Oct 12, 2006 | 06:32 PM
DeanM's Avatar
Hi,
I called some vendors who sell upgraded injectors for my 92 Cummins. One place said they sell Marine 370's. Another place said Marine 370 won't fit and they offer only 190's and POD's. I wrote to DDP and Ross said they offer Stage 3 and 4 for my truck. I am leaning towards the 190's cause I don't want a ton of smoke.
So will 370's fit my truck and how much do they smoke?
I am very happy with the power of my truck but seem to be insane and can't leave well enough alone.
Thanks Dean
Old Oct 12, 2006 | 07:33 PM
Firstgenner's Avatar
Dean,
The 370s are designed for the 2nd generation ('94-98) 12 valve engines and will not work on your rig unless someone has swapped engines to the newer design. Go with the 190s.
Old Oct 12, 2006 | 08:59 PM
Ilikebikes's Avatar
I have the DDP stave 4's. I only have maybe 1000 miles on them so far, but they are awesome injectors. Not too much smoke for the amount of power!
Old Oct 12, 2006 | 09:30 PM
Underpsi's Avatar
190's are not a large increase in power at all. just to let you know
Old Oct 13, 2006 | 12:05 AM
flashgordon's Avatar
From what i have been told if it has the smaller (intercooled) inj in it the 190 work good! For us "non intercooled" guys.......there is not much of an improvemt
Old Oct 13, 2006 | 12:31 AM
90firstgen's Avatar
I'd say you're looking at a 25 horsepower increase with the 190's... just a guess. I have the non intercooled injectors with bigger nozzles and my pump is maxed. I wish I had bigger ones. These aren't enough for anything more than what I have already. i don't have any troubles with EGT's either. The last mods planned for awhile are the HTT stage 4 and an old smokey fuel pin. That makes for some good speed on a light 2 wheel drive but as far as dyno numbers are concerned... I'm going to need some bigger injectors to make anything impressive.
My opinion... get something bigger than 190's, you'll be disapointed
Old Oct 13, 2006 | 07:39 AM
DeanM's Avatar
Thanks for the responses.
I have contacted a few more vendors and I am waiting for some responses. I heard the 190's are good for 30 hp or so. I sorta want more power than that.
Dean
Old Oct 13, 2006 | 08:21 AM
apwatson50's Avatar
I got the 190's and honestly was a little disapointed, at the time I didn't know about the DDP stage 3 or 4's and wish I would have held out for them.
Old Oct 13, 2006 | 09:15 AM
QIK2D's Avatar
anyone have anymore info on the 210's. they're on ddp's site, but i haven't seen anyone running them. i've got a set of pod's new in the box, but i think they'll be to hot for the towing i do.i think the 190's wont be enough. after hurricane season is over i will put the htt stg iv, 16cm housing, 4' exhaust, pacbrake, ford intercooler, 60 lb springs, 3200 spring,piston lift pump, and whatever injectors i decide on (my spare bedroom looks really cool right now). would just like some input on the 210's before then.
Old Oct 13, 2006 | 11:21 PM
swank's Avatar
try www.dieselperformancesolutions.com too. those are the injectors i'm running and am VERY happy with them. josh is a good guy to deal with to.
dave
Old Oct 14, 2006 | 09:46 PM
DeanM's Avatar
I did finally made a decision. I ordered 370 injectors from New Era Diesel. I had a hard time decideing between the 300's and the 370's. But I figure if I ever blow my turbo I would upgrade that so I might as well get the slightly bigger injectors now.
Thanks for you help
Dean
Old Oct 14, 2006 | 10:41 PM
90firstgen's Avatar
How much $$$$ did they cost you if you don't mind me asking
Old Oct 15, 2006 | 06:42 AM
Thanks for you help
Dean
Did you read post #2? Unless you have a p-pump the 370's will not work.
Old Oct 15, 2006 | 07:04 AM
DeanM's Avatar
I did read that post. My understanding is the 370's that I am buying are custom cut.
They cost $380 or $390 plus a core charge
Dean
Old Oct 15, 2006 | 09:27 AM
Sounds like a set of 370 tips on 1st gen bodies. Expect similar results to POD's.
