Conflicting injector info
2gen injectors will work.. but the bodies are different.. this really give you 1st gens a fair slection of injectors.. but the tips need to be moved to your 1 gen bodies.. and talk to your supplier about the pop-off settings.. as they are lower for the VE.. DDP will give you a setting or set them for you if you buy injectors or tips from them....
Bryan
Bryan
Ok, I got more info. I called the nice fellow Chuck, at New Era. He said the 370's that I ordered will not smoke as much as POD's. He also said that if I got too much smoke, for me, he would exchange them for something else. Sounds good to me.
Dean
Dean
DeanM I'm running a set of those injectors right now and really like them. I picked up a litte over 10psi of boost. They have a little bit of idle haze when it's cold outside but i think that it can be taken care of with the right pump settings. My truck will leave a nice light haze on a wide open run. The hole size on the injector tips are 5x12. For the money I think it is a good injector for a EDM.
DLittle,
Thanks for the feedback. What turbo are you running? I don't know what an HC1 hybrid is. What size is the comp.? I have the 60 mm.
I looked at a bunch of EDM injectors and New Era was the most reasonable price wise.
ddestruel
Jul 13, 2015 01:42 AM
chefgeorge
Apr 29, 2014 09:31 AM
powerrammaster
Jun 27, 2013 10:59 AM
kawi600
Jan 26, 2006 10:19 AM
