compounds with 351cw?
Old Mar 5, 2013 | 08:05 AM
BILTIT's Avatar
Starting research for the future, looking to do a set of fun driving/light towing compounds (12k# for maybe 2000km/yr). Wanted to use the 351cw as i have it. I found a hx50 that he says has a 17 divided EH and 67mm comp with internal WG, thoughts if this is a good match up?
Old Mar 5, 2013 | 01:33 PM
93flatbed's Avatar
What the exhaust side of a 50? I would think with an external gate you could keep the drive pressures down and it would spool wicked fast. But I know little to nothing about pairing compounds. As I've read it the primary should be able to flow double the seconday.
Old Mar 5, 2013 | 01:56 PM
BILTIT's Avatar
17cm2, has water cooling ports too. From what i can find the 50 flows 90-100lbs/hr while the 351 is 55lbs/hr i think.
Old Mar 5, 2013 | 06:21 PM
jimbo486's Avatar
The hx-50 sounds like it may be a little on the small side for a primary. Especially only have a 17cm turbine housing.
Old Mar 6, 2013 | 08:04 PM
93flatbed's Avatar
I was asking about exhaust wheel. I agree that it's a small primary but with the lack of rpm with these old pumps..... Plus the fact he will more or less need to "respool" each shift.
Old Mar 6, 2013 | 08:51 PM
BILTIT's Avatar
I sent him an email about the exh wheel size, in the ad it states its the smaller of the two hx50's if that helps.
Old Mar 6, 2013 | 09:42 PM
BILTIT's Avatar
Turbine wheel is 86/77mm
#2isgreen
Sep 3, 2013 10:10 AM
BILTIT
Oct 12, 2012 11:08 AM
4969joes
Jan 14, 2012 11:00 AM
darrenk
Aug 13, 2010 07:48 AM
wildcard3766
60
Mar 31, 2003 08:30 PM
