Cold Air Intake DNR
Old Jan 31, 2012 | 01:16 PM
fmackey's Avatar
Cold Air Intake DNR
I got a cold air intake from DNR Customs, love the way it sounds Its got a S&B universal filter, does it need oiled every so often or just blew out and how often?
Old Jan 31, 2012 | 04:27 PM
dB Zac's Avatar
I am not familiar with that brand but you should not use compressed air to clean filters
Old Jan 31, 2012 | 04:33 PM
Twitchy's Avatar
fmackey,
There is a S&B Filter cleaning and oil kit that you use to clean the oiled filter.
Old Jan 31, 2012 | 05:14 PM
anoldbiker's Avatar
When it comes to the oiled filters, there is a basic guideline to use. When the filter minder indicates it needs cleaning, or when you decide to clean it:
* remove filter,
* spray the solution to dissolve / loosed the debris,
* wait 10 minutes and rinse with a garden hose, (use normal hose pressure and not high pressure(,
* 'shake' out excess water, (no compressed air)
* let filter 'throughly dry',
* spray a 'light' coat of oil on filter and let stand, (don't over do it).
* after oil has soaked into filter, look for uncoated areas and touch up theses areas only with oil,
* after the additional oil has soaked in and filter is dry, install filter.
(I've found out the cleaner and oil from most all companies are somewhat similar and have bought the K&N from the local automotive stores, costing about $10 a box. Never had an issue with any manufactures filters. Save time acquiring and cost.)
The biggest problems people have with oiled filters are:
* water pressure high enough to break filter material,
* not allowing filter to dry before putting on oil,
* putting way to much oil on material and installing filter to soon,
* starting engine and sucking oil through filter into inlet tube and turbo fan blades.
When the filter material is moist, the oil will dissolve and flow quickly, then with the filter in this condition, the vacuum of the system will pull oil through the filter.
I've had these on 6 vehicles and up to or over 400k on some, never having problems as long as I've followed the above process. Takes a bit longer then most people want to do, but how often do you really need to clean them ? I do it once per year, if they need it or not.
Taquache
21
Jun 24, 2012 03:11 PM
wmbthe4
May 3, 2011 04:15 PM
herb
Jul 18, 2008 08:25 AM
Dodgewincity
13
Jan 19, 2008 05:41 AM
xloudnproud
Apr 5, 2006 06:38 AM
