Coil spring question
Redoing my ball joints and I have a question....do the Coil springs go back in a certain way? Any particular end up or down? I forgot! 😁
The bottom end of the coil spring fits into a recess on the lower control arm you might have to rotate the coil to get the coil to drop in, between the top of the coil and the bottom side of the upper control arm should be a rubber isolator.
Jim
TJE (03-19-2016)
flynhigh205
02-26-2008 10:33 AM
