Clunk When Decelerating...Fixed!
Old Apr 18, 2009 | 05:14 PM
14racing's Avatar
Pulled the old getrag apart this weekend and found the contershaft had about 1/4 of endplay. The countershaft bearings were junk. It was just a few miles from major disaster. Re-bearing and Re-shimmed it all put it back together and now the clunk is gone. Trans is much quieter too!
Old Apr 18, 2009 | 06:21 PM
oilcan64's Avatar
not sure if this is the same thing but when im on it then let off in high rpms (all stock though) the truck will lurch forward, this is normal right by the way its a 4x4, ohh and what do you run for fluid 5-30 synthetic and where do you overfill the top pto bolt hole
thanks justin
Old Apr 18, 2009 | 10:57 PM
14racing's Avatar
Yeah i run 5w-30 Amsoil Syncromesh and overfill it through the top pto cover bolt. Is it making a clunking noise or just lurching?
Old Apr 19, 2009 | 07:41 AM
oilcan64's Avatar
its just lurching, think it may be becuase of the weight/drag of the utility body, ill have to take it fir a ride again and get back to you
Old Apr 19, 2009 | 08:13 AM
Check the engine and trans mounts, the u-joints, and the rear axle for slop too. A worn cross pin in the diff is a common cause of this problem.
Old Apr 19, 2009 | 12:07 PM
oilcan64's Avatar
cool thanks
Cummins610
17
May 29, 2010 12:50 AM
14racing
Mar 17, 2009 09:50 PM
GasganoFJ60
Jan 19, 2009 08:41 PM
MasseyMan1089
May 23, 2007 07:56 PM
jlonghorn
Jul 18, 2005 09:04 PM
