Changing Rear-end fluid-Sythetic/limtied slip issues
Old Apr 12, 2010 | 05:22 PM
92roughstock's Avatar
IT's much quicker to just pull the one center and replace the clutches. Make sure you read the instructions about clutch order of installation.
Old Apr 13, 2010 | 06:56 AM
powerrammaster's Avatar
Same problem
I have a 93 with very low miles. Chatters after warming up, never for the first few miles. I am pretty confident I am the first one to have removed the diff cover. After 16,000 orig miles why would it chatter around corners with probably the factory fluid? I wouldn't think the clutches would have any problems in that short mileage. Orig axle for sure.
I replaced with Amsoil and kept spoon feeding additive with no luck also. Figure eights and all. Still moaning and chattering around corners. I used Sta Lube additive, should I waste the time with Mopar, it was equivalent.
I may have to replace clutches, how hard is it to do? Does Randy's provide good instruction? What tools other than common handtools are required?
Sorry about the hijack, but why reinvent the wheel here.
Old Apr 13, 2010 | 08:52 AM
GasganoFJ60's Avatar
Limited Slip Differential, Rear......GL-5*
ALL TEMPS......80W-90 [2] [3]
[2] Limited Slip Identification: Lift both rear wheels,
turn a wheel and other will rotate in same direction.
[3] With controlled slip, add 6.5%
Mopar Trac-loc additive or equivalent
txsmokindiesel
May 19, 2009 08:03 AM
TreeFarm
22
Mar 15, 2008 01:20 PM
dkinzer
May 23, 2005 08:57 PM
supr
15
Aug 4, 2004 03:33 PM
BADodge2003
Aug 24, 2003 07:22 PM
