changing 205 output bearing
Old May 18, 2013 | 08:28 PM
MARF75's Avatar
Can the output bearing be changed without pulling the tcase? If so, how hard of a job is it?
I had a vibration up around 75 mph originally, then after having the trans rebuilt, it started more around 65ish. Well now the output seal is leaking and I can move the yolk up and down a little bit while laying under the truck.
How much movement is too much?
Thanks
Old May 18, 2013 | 10:05 PM
BILTIT's Avatar
Which output? I imagine you mean the rear output bearing. Yes it can be done easily. Pull the yoke and bearing retainer off (seal holder), bearing will slide off with a little coaxing.
Thats what i did to get this on.
Old May 19, 2013 | 06:38 AM
MARF75's Avatar
Yes I was referring to the rear, oops, forgot to specify. Thanks for the pix BILTIT! Is the bearing pressed on? Do you have to pull the output shaft?
Is that a gear vendors OD? Those things are pretty neat, although I don't totally understand how they work. Kinda like a 2 speed rearend?
Old May 19, 2013 | 07:41 AM
BILTIT's Avatar
Not pressed on, just slides off. Yup they are just like a 2 spd rear diff.
Old May 19, 2013 | 07:54 AM
sooty's Avatar
internal pump generates oil pressure to engage over/under drive planetary, you need to be moving around 25 mph to engage for a 30% ratio change, with my 5 speed, I get 7-8 useable towing gears, with splits on 2nd 3rd and 5th, they add an otherwise unknown beauty to the backside of the 205. my jeep has 5' of gearboxes, the sm465-203 range box- ord adapter-205 tcase-gv overdrive, 4x4 ratios: 1:1- 2:1-4:1, 7 forward gears on road.
Old May 19, 2013 | 12:11 PM
MARF75's Avatar
Thanks for your input guys! Probably gonna order bearing,seal and yolk tomorrow. Also might have a new rear drive shaft built in the near future.
Free89W350
Jul 23, 2009 12:27 AM
Emoo60
Jul 11, 2008 07:07 AM
D1EZEL
Nov 22, 2007 02:55 PM
G1625S
Feb 18, 2005 04:17 PM
Gabe
May 4, 2004 11:44 PM
