CB's
CB's
Hey guys....I just got a cb and dual 4ft antennas, putting them in this weekend.Just wondering how many of you guys are running cb's and antennas? Where did you mount your cb/antennas? Pics would be great.Thanks.I'll try to get some pics of the install.
i mounted my antennas on my side mirrors but its not the most solid place to mount them i mounted the cb on the cieling above where my rear veiw mirror use to be i like it there because it s out of the way but it is a bit hard to see what channel your on.i dont have pics but i hope that is descriptive enough
lil wilson in the center onf the roof w/ great reception, and a corba lt somethin somehtin its nice, its mounted right under the radio i lost the ash tray when mounted there but wires are ez to run and looks great im to lazy to take pics and gtg to work ne wayz good luck!
I am still looking for a CB antenna "fender mount" bracket. Is anyone running one of these setups? I'd like to know what brand makes them and a possible part #.
I have a cb and mounted it on the ash tray which still opens and mounted 2 5' antennas on my headache rack which came out really sick. I am gettin alot better reception with two than i did with one. If youve got a headach rack i think that is the ideal place for the antennas.
The po mounted my CB under the glove compartment. Its out of the way, but too far away to adjust when I'm driving, don't mount yours there. My antenna is mounted on top of the drivers side front fender. A bracket mounts in the gap between the fender and the hood. Don't mount your antenna there either, the bracket rubs the paint off the side of the hood. Sometime when it warms up, and I've got some extra time, I'll move the CB to under the radio, and move the antenna behind the cab in the corner of the bed.
I've got a a Wilson 2000 mounted to the toolbox and the cb mounted on an overhead console. My las 93 I had a Wilson 1000 roof mount and the radio mounted to the ceiling. I used a short 2x4 in between the metal roof and the headliner. I've also used a mount that holds the radio at an angle and has v-notches on the bottom that grip on the carpet. Wherever you decide to mount the antenna, make sure its grounded good.
Same here on my personal truck; the ceiling mounting is the most convenient, out-of-the-way, place for the radio, with the antenna(es) being most out of harms way mounted on the mirror(s).
The wife's came with the C.B. mounted in a custom OAK overhead console, way over on the right side; it makes it a little hard to make adjustments, but it is always on 19 and the ***** hardly ever get touched, so it works out okay.
You might want to look at a 'Geotool' stake pocket mount. I met the guy that invented them at a computer swapmeet in Redondo Beach at least 10 years ago. He said he was a Geologist. When he would go out to the desert or the mountains his regular mounts did not hold up.
He designed this mount for the stake pocket and it's not bad. One big plus, you don't have to butcher your truck for the sake of a mount. The only drilling would be out of sight in the bottom of the stake pocket. They are not cheap, about $75, but they are a clean mount that can hold just about anything should you gravitate beyond CB. Just type in Geotool.
