can I run these injectors?
Old Jan 27, 2010 | 02:00 PM
440forPOWER's Avatar
Hello has anyone used these injectors? http://www.dynomitediesel.com/display_part/247.php Are they any good? Feel any power difference over stock? Can I run these in a basically stock 93? I plan on better exhaust in the future but right now all I have done is turned the fuel screw about 1 turn and put a bully dog pin in it. Just looking for a little more power. Thanks
Old Jan 27, 2010 | 02:22 PM
Rick 12v CTD's Avatar
I think you'd be better off getting the Stage IV 80hp sticks instead. The 55lpm stage IV sticks gave me about 65 hp over stock at the wheels. I think you can get the stage IV 80 hp sticks all the way up to 65 lpm which would give a pretty substantial power increase. And yes you can install these on a stock engine but to get the best results with them you'll want more air too.
Old Jan 27, 2010 | 02:24 PM
SOOT4BRAINS's Avatar
Pod Boy (on hiatus)
With a hybrid turbo, 4inch exhaust, turned up pumpand a good fuel supply I made 331 hp and 750 tq with a set of these. Good injectors, ran pretty clean and better mileage than my stockers. I think some one made almost 400 hp on these as well, can't remember now. You should be fine to run these in a mostly stock truck. A hybrid turbo upgrade would be a good idea if you plan to run the pump turned up.
Aaron
Old Jan 27, 2010 | 03:29 PM
Good injectors for a mostly stock truck.
Is your truck an automatic or 5 speed?? If its an auto i'd spend the money on a good torque converter, you'll feel way more power with what you have now going through a good converter, more power than just putting bigger injectors in and leaving the stock torque converter.
Keep in mind when you add the injectors you should advance the timing to get the full benefit of the power , (you might as well just do it now and still gain some pwower)
Old Jan 28, 2010 | 02:48 PM
This is an automatic. I plan on doing the converter when I have the tranny gone through. Probably next year. But for now I thought about giving these a try. I looked at the 80hp ones but they say you need a bigger turbo for these. Plus I still do a bunch of towing with this truck. Thanks
Old Jan 28, 2010 | 04:55 PM
Richie O's Avatar
366 Spring Chicken
You can run a stock turbo as long as you don't get crazy with the fuel screw.
Old Jan 28, 2010 | 05:14 PM
SmokemS's Avatar
you can run a stock turbo with pod's ....i have no problems
Totallyrad
Jul 19, 2011 07:41 AM
MoPowa
Apr 4, 2009 12:47 PM
SUPRDUD
Jan 31, 2009 07:36 PM
loco one
Nov 25, 2007 10:50 AM
