Busted Spring Pack
Old Jun 15, 2008 | 09:43 PM
mhuppertz's Avatar
Busted Spring Pack
I have a broken centering pin on my front, left axle. This is causing the u-bolts to move no matter how tight I have then cranked down. I have a replacement set ready to go, but my question is this: do any of you think that movement could change the camber enough to wear my tire move on the inside?
Old Jun 15, 2008 | 10:59 PM
Alwaysworking's Avatar
alwaysonDTR
i think so, pushed back on one side would wear different in a turn than if they were both the same.
Old Jun 16, 2008 | 05:50 PM
Richie O's Avatar
366 Spring Chicken
Its a solid axle, I dont think it would change anything but it isn't safe with the axle moving back and forth.
Old Jun 16, 2008 | 07:26 PM
ccab85's Avatar
center pins run about 3-5 bucks and 30 min to change. Way too cheap to risk life and limb for. if you need pins PM me and I will send some.
Old Jun 16, 2008 | 11:17 PM
big stinky's Avatar
Ya man, your crazy, fix it!!!
Tire wear on the inside could be a toe out situation.
mullishacrew
Oct 22, 2008 07:54 PM
tauberson
May 2, 2008 08:59 AM
Joe T
16
Jun 12, 2007 12:11 AM
davedye
Nov 24, 2006 06:32 PM
Ramasaur
Aug 21, 2004 11:57 AM
