bright lights ebay
Old Jan 15, 2008 | 08:44 PM
bobva's Avatar
bright lights ebay
http://cgi.ebay.com/ebaymotors/ws/eB...m=250205487679
I did the math with fuel run around time, couldn't build them for that price
thought I'd share
this isn't the only set theres 3 or 4 dealers
Old Jan 15, 2008 | 10:26 PM
MikeThomas's Avatar
I went ahead and bought a set. I let you know how it turns out
Old Jan 15, 2008 | 10:31 PM
Jim5870's Avatar
Looks like a good kit! should save you some time than putting it all together from scratch
Old Jan 20, 2008 | 10:36 AM
MikeThomas's Avatar
So I got the kit today. Looks pretty good. Things are triggered by one headlight plug feeding two 40a relays. The plugs on the headlights are 14ga, including the grounds, and each relay has its own 25a fuse. The only thing I dont like are the pink plugs and fuse holders. Other than that its about what I expected...chinese relays etc....we'll give it a shot!
Old Jan 20, 2008 | 03:18 PM
bobva's Avatar
got mine today also
Mike did discribed them good
the set I got had some diodes in it
set did not work on low beam
cut them out they work great
replaced factory yellow relays with 30 amp black boschs
Old Jan 20, 2008 | 05:07 PM
MikeThomas's Avatar
Where are your diodes at? Are they on the plug ends?
Old Jan 20, 2008 | 05:42 PM
bobva's Avatar
pm sent..............
Old Jan 20, 2008 | 08:34 PM
MikeThomas's Avatar
So I did as Bob said and opened up the harness and remove the two diode setups. The smaller one that is at the "input" plug just unplugs, but the one inside the main harness I had to cut out and put a butt splice in there. All I can say is : WOW :, Ive got some bright headlights now! Definitely worth the $32 bucks since I did not have to source the parts from different places.
Mike
Old Jan 20, 2008 | 08:50 PM
DanMan's Avatar
bobva, did you try them before you put the Bosch relays on? If so, did they make any difference or are they more for peace of mind/reliability?
Old Jan 20, 2008 | 08:55 PM
MikeThomas's Avatar
Exclamation *****note*****
When you delete the larger diode, do not connect the blue wire back into it, just connect the white ones. If you dont, you pretty much run both beams at once...they brighten when you hit the high beams, but I think its only because your are providing two +12v supplies to a filament.
Old Jan 20, 2008 | 09:13 PM
bobva's Avatar
safety 40 amps is two big for the lights in my truck.
tomorrow the 25 amp fuses will be placed with 15 or 20 amp fuses
It's better to under amp than over amp 10 cent fuse I can pop lots of them
over amping your breakers leads to fire
Old Jan 20, 2008 | 09:14 PM
torquefan's Avatar
I bought a relay kit from Summit a couple years ago. It had some real funny looking Chinese relays it it, which actually only lasted a couple months. Of course these relays had some really obscure footprint, and I couldn't match them up anywhere, so I ended up replacing the relays AND connectors. At least the relay kit shown here appears to use a common ISO relay and connector. That's a point in its favor.
Old Jan 20, 2008 | 09:25 PM
DanMan's Avatar
I just ordered one, I'm looking forward to even brighter lights!!
I'd like to thanks you guys for jumping on these right away so that now the rest of us know how to modify it to work best in our pickups.
Old Jan 20, 2008 | 09:27 PM
bobva's Avatar
for 30 bucks great assembly. I did the math If I built this from scratch 60 bucks plus
light sockets 20
wire 20
relay sockets 20
fuel 20
and ontop of all that I'd have lots butt connections in my lights
Old Jan 20, 2008 | 09:35 PM
bobva's Avatar
http://www.4crawler.com/Diesel/Cheap...OnLineOrdering
I think these are plug and play I just didnt like the yellow sheath
their also on ebay
