Which books
Old Apr 4, 2006 | 05:14 PM
Cowboy_Customs's Avatar
Which books
I was wondering what books ya'll use for 1) the truck itself 2) the cummins engine.
I usually buy a chiltons (which I have to order on-line)
I havent read the valve adjustment article as of yet, but I will be as I plan on adjusting the valves this weekend sence I have to do the valve cover gaskets.
Thanks again!
Old Apr 4, 2006 | 05:28 PM
92DIESEL's Avatar
Only the bible will do. '93 FSM has the getrag rebuild or if you don't plan on the trans rebuild you can get the '92 FSM
Found on Ebay sometimes
Good Luck,
Michael
Old Apr 4, 2006 | 05:43 PM
BC847's Avatar
1st Generation Admin
You can get a copy of the FSM at Geno's for $89 ~ http://www.genosgarage.com/CoastalDa...D=1823&CATID=1
Then look on Ebay for a Cummins "Shop manual B series engines". (Be sure it includes your year). That will cover the long block.
Old Apr 5, 2006 | 05:31 AM
bgilbert's Avatar
Chiltons and Haynes are good for the truck. The bible is actually the Cummins B-series troubleshooting and repair manual, published 10-99. Can be had from Cummins for ~$75, or ebay for half to $50+. DO NOT buy an operations and maintainence manual for the Cummins B-series. Waste of time and money. Shows you how to change your oil and check it, duh.
Old Apr 6, 2006 | 04:59 PM
Cool deal, Ill be sure to grab the FSM, and a chiltons. Thanks!
Old Apr 6, 2006 | 05:48 PM
apwatson50's Avatar
If you get the FSM there is no need for a Chiltons. The chiltons is like a service manual for dummies. Everything you need is in the 93 FSM. Chiltons has like 2 pages to cover the diesel engine.
t-15 firefighter
Sep 22, 2005 11:39 AM
Mopar1973man
Apr 27, 2004 05:55 PM
cumminsjunkie
Dec 19, 2003 04:11 AM
ouchman
Apr 7, 2003 01:32 AM
