Best upgrades for towing ? ? ?
Old Jun 6, 2012 | 07:55 AM
440727's Avatar
I have a 1992 Dodge Ram D-350, 5spd, and 3.54 with 93,000. I'm going to work for my father-in-law in his construction business.
What would be the best upgrades for towing 10k-15k a few times a week in arkansas ?
Thanks !
Old Jun 6, 2012 | 08:12 AM
1972RedNeck's Avatar
Brake controller.
Old Jun 6, 2012 | 08:20 AM
440727's Avatar
Got that thanks !
Old Jun 6, 2012 | 08:52 AM
I just went through this..
https://www.dieseltruckresource.com/...l-t303179.html
I need to address my rear suspension, as the rear springs are not sufficient for adding a trailer after 20 years without doing so.
I'm going to have my rear springs rebuilt and add an air ride system to the rear sector.
You should change out your gear oil and switch to a severe duty gear oil such as the 75-140 weights... and don't forget your additive if you have a limited slip diff.
Old Jun 6, 2012 | 08:58 AM
ppiggppenn's Avatar
All the above, incl synthetic engine oil in the Getrag. I tow somewhat lighter than you, (5th wheel camper trailer) and my most persistent problem has been coolant overheating. This off-season I swapped out the radiator so we'll see what happens this summer.
Old Jun 6, 2012 | 08:59 AM
Replace the brake system and make sure it's working perfect, rears are adjusted, drums are turned straight, shoes are high quality so they won't crack. Make sure the front rotors are good and thick and haven't been cut 10x.
You won't have a problem pulling it. Stopping on the other hand.
I'm about to convert to Hydroboost brakes, i'm expecting a drastic improvement when towing.
Old Jun 6, 2012 | 11:54 AM
AirLiftCompany's Avatar
Starter Sponsor
Suspension wise you may want to consider adding extra load support for the rear springs depending on how much your truck ends up squatting. You could do this a couple of different ways such as rearching your leafs, replacing them, adding a leaf, or adding air bags.
If you consider air bags and look at our products, the kit for your application would be 57215. If you have any questions regarding adding air I would be happy to help even if they are questions about other companies products.
Old Jun 6, 2012 | 09:48 PM
Great advice....
Make sure your electric trailer brake controller is functioning and dialed in correctly based upon the load you're hauling. I recently set mine up, and it explained in the instructions that I travel ~25mph, and actuate the brake controller multiple times to where the brakes do not lock up, and sufficient stopping power is applied. Balanced brakes are important, as with not enough on the settings will overtax your braking system, and too much will lock up the trailer brakes each time you apply them.
Old Jun 7, 2012 | 12:40 AM
u.s mma's Avatar
how much do you want to spend?
Old Jun 8, 2012 | 01:58 PM
440727's Avatar
I'm willing to spend up to $1000.00
Thanks guys !
Old Jun 8, 2012 | 02:34 PM
Gots_a_sol's Avatar
Be very gentle with the pedal the first time you go to stop after doing so, I almost ate my steering wheel when I converted my truck the first time I hit the brakes
Old Jun 9, 2012 | 05:05 AM
KRB's Avatar
KRB
Ditto on stopping being the weak link.
I'd invest in some gauges too so you can monitor the systems. EGTs, etc.
Have you already overfilled the Getrag? They don't like to be lugged in 5th.
Old Jun 9, 2012 | 05:26 AM
Jim Lane's Avatar
Get a good exhaust brake and HD valve springs and let your engine compression stop you, no sense wearing out your friction brakes.
Also gauges, don't want your EGT getting away from you on a grade.
wild4stangs
14
May 27, 2013 02:05 PM
JDeere5105
Jul 14, 2007 09:20 PM
benderbrew
Aug 12, 2003 11:33 AM
RickCJ
Feb 28, 2003 12:46 PM
