Bad Vibration??????
Old Jul 7, 2003 | 09:13 PM
GaCamper's Avatar
Bad Vibration??????
Open for suggestions.....My 93 D350 has pickup up a vibration in my truck and it gets worse the faster I go. I don't notice much 55 mph and under. But I do notice it 55 mph and higher. Sometimes it seems to come and go. But it never really goes away. Sometimes I feel it in the seat sometimes in the steering wheel. Sometimes the whole truck seems to vibrate. The truck has 6 new tires and they all have been balanced twice. I've replaced all 3 universal joints. Any suggestions where or how to start to look for the cause of the vibration ???<br>
Old Jul 7, 2003 | 10:26 PM
carl20320's Avatar
Re:Bad Vibration??????
Had a very similiar problem. Mine turned out to be the u-joints. Since you replaced those, is there any chance your drive shaft is out of balance?<br><br>Carl
Old Jul 7, 2003 | 10:41 PM
CrewCab's Avatar
On my '81 it was a slightly warped front rim. Moved it to the back and everything was ok.<br>Terry
Old Jan 30, 2007 | 05:46 PM
ScottT80's Avatar
Anyone else have any suggestions on this? Did you ever get it fixed? (I know its been 3 1/2 years ago...)
Old Jan 30, 2007 | 06:24 PM
pred's Avatar
Through some tire balance powder (name escapes me now) in the tires,
Have you a buddy you can swap wheels and tires with, that will sure reveal something!
If your drive shaft is a split type, 2wd, pull apart center u joint, and rotate yokes 180*
Peter.
Old Jan 31, 2007 | 10:57 AM
dpuckett's Avatar
I had a bad vibration at 55+ MPH; turned out to be worn front wheel bearings. Replaced bearings and races, and it all but went away (I have 2 bald front tires that I got used, cause they hold air- and they didnt balance real well. Vibration gets better at 75+).
Daniel
boosted7
May 4, 2010 10:09 AM
65fury
25
Apr 6, 2007 08:16 AM
dodgedsl03
Jan 18, 2007 10:08 PM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
