Auto trans question
Old Sep 20, 2006 | 10:39 PM
ouchman's Avatar
Auto trans question
My transmission seems to slightly slip between first and second, especially if I'm accelerating harder. It's not real bad, but it's noticeable. Is this an adjustment-type thing? Also, what kind of ATF is recommended? Thanks -
Old Sep 20, 2006 | 10:43 PM
marksmith's Avatar
Yes its an adjustment type of thing.
Adjust front and rear bands.
Go to you local tranny shop and get a metal accumulator piston. Pull your valve body and replace the piston. Factory one is plastic with a spring on it. Pull both and put just the metal piston back.
Should solve your 1-2 slushy shift problem.
Old Sep 20, 2006 | 10:44 PM
marksmith's Avatar
PS ATF+3 is what chrysler runs in them factory.
Put two quarts NON-Detergent 30wt in it. It helps keep shifts firm.
Old Sep 20, 2006 | 11:19 PM
flashgordon's Avatar
hadn't heard of that before.......are the seal compatable with that?
Old Sep 20, 2006 | 11:25 PM
marksmith's Avatar
Non detergent will not hurt the seals.
All it does is help keep the fluid a little 'thicker' while hot... and MAYBE a little help with the gription of the bands.
Old Sep 21, 2006 | 08:06 AM
Boatnik's Avatar
Putting Lucas Transmission treatment will firm up the shifts too, but I would want to adjust the bands first.
Old Sep 21, 2006 | 08:09 AM
Mcmopar's Avatar
Do you put ATF in the crankcase too? Don't do it, not a recommended practise.
Old Sep 21, 2006 | 03:15 PM
goodtyms's Avatar
I'm not a auto tranmission expert, but Type F is supposed to firm up the shifts because in not as slippery.
Old Sep 21, 2006 | 05:15 PM
ouchman's Avatar
Go to you local tranny shop and get a metal accumulator piston. Pull your valve body and replace the piston. Factory one is plastic with a spring on it. Pull both and put just the metal piston back...
Ok. Please explain to a transmission-virgin what and where these are. Maybe point me to a thread that can explain the procedure... Is it something a novice (but not an idiot) should attempt? Also, where can I find out how to adjust the bands?
Just in case - what should I expect to pay an auto shop to do this? Vs doing it myself?
Old Sep 22, 2006 | 08:33 AM
goodtyms's Avatar
Adjustment of the bands is pretty simple. There are adjustment screws/bolts with jam nuts on the side of the transmission. Kind of a pain to get a wrench on with enough room to turn. Most service manuals will give directions on how to adjust. Do yourself a big favor and pressure wash the trans first!
DodgeDiesel61
Jun 3, 2008 07:50 PM
jca001
Mar 8, 2005 04:42 PM
KSmith
Jun 10, 2004 07:23 AM
KC
Nov 22, 2002 09:12 PM
KC
Nov 18, 2002 02:05 PM
