Anybody useing a hx55 for twins?
Old Jun 29, 2009 | 09:54 AM
sleeperman's Avatar
I got a hx55w for very cheap and want to use it for twins and didnt know if it would work very good or if anybody was using this for twins or a big single? What do I need to make it work good with my hx35?How big of injectors can I run with this set up? And what kind of hp numbers would it make?
Old Jun 29, 2009 | 10:13 AM
RowJ's Avatar
Too small for big power but could possible work for moderate HP...if turbine housing is big enough.
Usually they are not that big because the 55 is designed as a single.
Is it Wastegated? Would have to be to work in twins, I think.
RJ
Old Jun 29, 2009 | 10:15 AM
apwatson50's Avatar
Originally Posted by RowJ
Too small for big power but could possible work for moderate HP...if turbine housing is big enough. Usually they are not that big because the 55 is designed as a single.
Wastegated?
RJ
How does it compare to a k31?
Old Jun 29, 2009 | 10:16 AM
RowJ's Avatar
I know little about the K31's other than that they are just a tad smaller than S400, I've been told.
RJ
Old Jun 29, 2009 | 11:07 AM
sleeperman's Avatar
It is wastgated and how much smaller is it t an ht3b?
Old Jun 29, 2009 | 11:29 AM
RowJ's Avatar
Resurrected this from my "saved threads" file....
Turbo_______CFM____Racing HP_____Daily HP
HX35_______600________420________330
HX40_______800________560________440
HX50_______1000_______700________550
HX55_______1050_______735________578
HX60_______1600_______1120_______880
H2E________1000_______700________550
HT3B_______1100_______770________605
HT4B_______1800_______1260_______990
HT60_______1400_______980________770
T66________800________560________440
T76________1350_______945________743
T88______1450-1750__1015-1225___798-963
T91________2000_______1400_______1100
T100_______2600_______1820_______1430
T105_______2900_______2030_______1595
Big Brother__1900_______1330_______1045
Old Jun 29, 2009 | 04:25 PM
Well stackx2 has a 91 VE pumper and he runs a HX35/HX55 twin setup at 55psi
PM him. https://www.dieseltruckresource.com/...er.php?u=65984
Old Jun 29, 2009 | 05:08 PM
apwatson50's Avatar
What size is the down pipe outlet on the 55?
Old Jun 29, 2009 | 07:43 PM
sleeperman's Avatar
I thank its around 2in or 2 1/4 somewhere around there.
Old Jun 29, 2009 | 07:46 PM
RollinCoalSmoke's Avatar
I got the pieces together in the last 3 or 4 days to build a 5'' to 4'' adaptor for the downpipe. Don't know why maybe i'm just being a good boyscout being prepared. I've ended up with several turbos that I have no clue to what they are. Most all of them are off of big trucks.
Old Jun 29, 2009 | 08:24 PM
No he means the Exhaust outlet. the hx55 looks ot have a 77mm turbine.
I read this thread and Came up with the HX55 having a 67mm compressor inducer. very small as the big turbo in a twins setup. As of now im calling this turbo a 65/77/22 ...one guy said he had a hx55 with a 16cm housing, idk
http://www.theturboforums.com/smf/in...002.msg1055805
Looks to have a 22cm exhaust housing going by one of the pictures in two links down
http://www.competitiondiesel.com/for...ead.php?t=2577
Also check out all these pictures of measurements of the HX55 i found- http://www.cecoatings.com/images/Car...lsetHX55Turbo/
Old Jun 29, 2009 | 08:29 PM
5"
Or 4.5" can't really tell in the pictures link i posted above ^
I read the guys gauge in all these pics http://www.cecoatings.com/images/Car...lsetHX55Turbo/
And then punched in the numbers like 3.030 (3 in. and 30 thousandths) into this IN. to MM calculator http://www.cecoatings.com/images/Car...lsetHX55Turbo/
Still getting 65ish compressor, 77ish turbine, and I see a 22 stamped in this pic- http://www.cecoatings.com/images/Car...o/DSC00765.JPG
To come up with the compressor inducer Dia. do you measure this part- http://www.cecoatings.com/images/Car...o/DSC00760.JPG OR THIS PART- http://www.cecoatings.com/images/Car...o/DSC00761.JPG
Old Jun 29, 2009 | 08:57 PM
Hope i helped some
Old Jun 30, 2009 | 08:06 AM
RowJ's Avatar
... the HX55 having a 67mm compressor inducer. very small as the big turbo in a twins setup.....
HX-55's were mfg'ed with 64mm, 66mm, 72mm, 74mm and 76mm compressor bores. Looks like it's been done successfully and does work?
So it depends on which size 'Sleeperman' has.
I can tell you the primary turbo on my BD twins has a.......
66 mm compressor wheel
77 mm Turbine Wheel
20 cm2 exhaust housing (1.10 A/R)
Works great and runs cool up to 500 hp and 50 psi boost!
I added H2O/Meth and stay cool at 600 hp and 65 psi boost. (Primary turbo puts out 30-32 psi at WOT).
RJ
Old Jun 30, 2009 | 08:16 AM
What did the HX-55 come off of? Was it on a truck ect? I think someone once mentioned it came off a Cummins 855.
