Any advice on the KDP fix.
Old Feb 25, 2010 | 02:20 PM
Fred the Farmer's Avatar
hey all,
i bought the KDP kit from source automotive and was wondering if anybody had any pointers and if there was anything i should change while i'm doing this.
Thanks.
Garrett
Old Feb 25, 2010 | 02:47 PM
tenny1981's Avatar
dont forget to put locktite on the case bolts and torque them. There are I think 2 bolts under the cam gear, like 5 or 6 total in the case.
Old Feb 25, 2010 | 02:51 PM
ok thanks sir i will do that.
Old Feb 25, 2010 | 02:52 PM
TIMMY22's Avatar
Click here...http://www.tstproducts.com/DowelPina.pdf
Generic directions for 1st and 2nd gens...
Old Feb 25, 2010 | 05:44 PM
DNRCustoms's Avatar
Air ratchet to for all the bolts that hold the cover on!!
Old Feb 25, 2010 | 05:54 PM
yea i'm sure it will help, and go alot faster
Old Feb 25, 2010 | 06:32 PM
1985cucv's Avatar
make sure you get that front seal lined up correctly and take your time if you are putting it in!
Old Feb 25, 2010 | 08:48 PM
yea i am, is it hard to put in or something.
Old Feb 27, 2010 | 11:24 AM
sdseva's Avatar
you get it in yet? i think i will do mine soon too so let us know how it went
Old Feb 28, 2010 | 12:53 AM
yea i just took my old seal out, but i guess the easiest way to put the seal in is with a big edit socket and lightly tapping it with a hammer.
Old Feb 28, 2010 | 03:58 PM
zig100's Avatar
My seal came with a clear plastic guide to help get it back on. I just put the seal in the cover, then put the guide on the shaft (large side on the shaft) then you gently push it on. Of course I learned this after trying it another way and having to buy a new seal!!
Old Feb 28, 2010 | 04:02 PM
zig100's Avatar
Oh, I see you were talking about getting the seal into the cover. Yeah, a socket, or just tap it evenly from both sides,,, carefully.
Old Feb 28, 2010 | 05:43 PM
Trebor's Avatar
Use the seal installation tool. It keeps it "square" in the bore. Always follow the instructions in the service manual.
Old Feb 28, 2010 | 05:58 PM
BC847's Avatar
1st Generation Admin
Perhaps helpful info can be found here ~ https://www.dieseltruckresource.com/...-t126282.html?
(As found in The Sticky).
Old Feb 28, 2010 | 07:58 PM
ok thanks guys, just finished it today, i didn't know that tool was a tool and i tryed putting the seal on the shaft and i put a little crack on the yellow part, i tryed super gluing it let it dry, then reinstalled everything and i'll have to see what happens, i think i'll have to get a new seal sometime, but i'll stick with this one for a while.
