Another injection pump install question
Old Jan 6, 2011 | 10:59 PM
The_Head's Avatar
My injector pump was sealed to the timing case with some kind of sealant. This prevents me from rotating the pump to change the static timing. I want to fix this, but I dont want to screw anything up. Is it possible to slide the pump back enough to remove the gunk and install a gasket without disturbing the cylinder timing?
I am kind of dumb about this stuff. I'm going to go watch the injection pump recall video on youtube now.
Old Jan 7, 2011 | 02:05 AM
ofcmarc's Avatar
Just pull the pump. It ain't that bad.
Pull the throttle brackets, and the injection lines. Remove the oil fill tube and IP gear nut. Roll the engine over until the Key is pointing up. Lock the pump in place then press the pump off the gear.
Fix the gasket problem the reinstall the pump.
Piece of cake.
Old Jan 7, 2011 | 03:53 AM
GLHS's Avatar
You worry too much.
Any movement will affect timing so no, you can't do it without affecting timing.
You could crank that pump as far as you want one way or the other and not mess anything up.
Move it however you want and when you find a position you like, leave it.
Just measuring from the head over to the afc will give you a close enough before and after position.
As you already know turning the pump towards the drivers fender retards timing reducing lag, causes higher cruising and towing egt's, limits high rpm, will give higher boost readings and a quieter engine.
Rotating towards the head will advance timing causing more initial lag, lower cruising and towing egt's, higher revving engine, lower boost readings and a louder, rattling engine.
Some just jump the gear a tooth or two which is equal to 10 and 20 degrees advanced.
IIRC the total adjustment possible just by rotating is .75mm (7.5* approx) to 2.35mm (23* approx) of timing which is about 15* of total adjustment.
This is a pretty close ball park mm wise if your pump is using the factory cam plate which, more than likely it is.
tommurray
Feb 23, 2014 10:38 AM
Rowdy 1
Mar 28, 2007 06:38 PM
AltavistaLawn
20
Nov 16, 2006 08:17 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
mikmaze
Aug 13, 2006 12:26 AM
