another fuel screw question
Old Feb 14, 2009 | 06:27 PM
zethtays's Avatar
ok so after installing a 366 spring I had to fight the fuel screw to get it back close to prior settings. the previous owner has evidentally played with it quite a bit as it lacking threads past nut and the end is completely rounded off and the flathead slot is even gone, is there somewhere were i can get a replacement and turning the screw inwards towards pump is to increase fuel and backing away from pump is backing the fuel down as well correct??
Old Feb 14, 2009 | 07:39 PM
rebal's Avatar
go to a local injection pump shop that deal with Bosch parts and you are correct, in = more fuel,out = less fuel
Old Feb 14, 2009 | 07:45 PM
Bob Beauchaine's Avatar
When you go to a Bosch certified rebuilder they will want the serial number off the pump - hope you can read upsude down.
Bob
jmd4993
Jun 22, 2013 07:36 AM
STACKED
Sep 25, 2008 09:07 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
loudcummmin
Oct 3, 2005 02:44 PM
