alternative fuels
Old Jun 27, 2007 | 10:28 PM
Exekiel69's Avatar
alternative fuels
How does the cummins (ve pump mainly) handle other fuels like wvo and also bio diesel? I know about the rubber parts with the BD but what about the wvo? I know this pumps don't need much more than 7-9psi, right? how about the rest of the engine?
Thank You.
Old Jun 28, 2007 | 11:52 AM
edwinsmith's Avatar
The methanol in biodiesel will attack the rubber in the older VE pumps but any other oils will be OK. An updated gasket/o-ring kit is about $20 and isn't to hard to install if you want to run B100. I think biodiesel blends up to B20 will be ok even in the older sealed pumps.
Edwin
Old Jun 28, 2007 | 06:08 PM
Make sure the WVO is hot and the hard parts will be OK. The original rubber will get eaten up eventually.
Old Jun 28, 2007 | 07:34 PM
Exekiel69's Avatar
I read the sticky for replacing seal already so that will be covered (no problem spending $20 to save fuel from leaking latter) before the drop IN.
Ray Roton
Jan 27, 2007 05:30 PM
KATOOM
23
Sep 15, 2005 08:51 PM
storx
Sep 4, 2005 08:04 AM
