Adding another pulley wheel
Old Jul 15, 2010 | 10:33 AM
grim's Avatar
im wondering if anyone has had success in adding another pulley wheel up front for an additional belt driven accessory? Im thinking of a pump specifically.
Old Jul 15, 2010 | 12:20 PM
BearKiller's Avatar
I added a separate V-BELT pulley system that drives my Ford A/C and the belt-driven vacuum pumps for the trailer brakes.
I was fortunate to have a brand-new shiny zinc-plated B pulley that was exactly the right diameter for the job; this pulley was in a big box-lot that I had bought at an auction years before for probably a couple dollars.
I had my machinist/genius re-cut the center and lathe-mark/drill the six holes, such that this B V-belt pulley is immediately in front of the fan pulley.
I very much prefer my auxilliary V-belt system over adding more serpentine pulleys and a longer EXPENSIVE belt.
It is a simple matter to eliminate any offending unit that is V-belt driven; not so when one long belt does it all.
I doubt there is room between the fan blades to do likewise with a secondary serpentine-belt system; maybe a 4-rib, but not an 8-rib.
Old Jul 15, 2010 | 01:59 PM
grim's Avatar
yeah i was thinking a v belt would be best for sure. just wondering how would be best to mount it and to what? would the alternator position be a good choice? and what was your method of disengaging it?
Old Jul 16, 2010 | 03:11 PM
grim's Avatar
anyone else have any experience with doing this?
Old Jul 16, 2010 | 04:03 PM
Onemoparnut's Avatar
I know there is a v belt pulley that can be added to the alt but I forget who makes it.
Old Jul 16, 2010 | 05:26 PM
saggonwaggon91's Avatar
What pump are you trying to run and why would you want to disengage it? Mine has a hyd. pump mounted high on the driver side with a a/c type elec. clutch.
Old Jul 16, 2010 | 06:14 PM
grim's Avatar
im thinking about mounting a haldex hyrdaulic pump for the purpose of pumping veggie oil through a centrifuge. engage/disengage for while filtering or not.
Old Jul 16, 2010 | 11:36 PM
BearKiller's Avatar
I am a little confused by the question.
My V-belt drive pulley is direct-bolted onto the same bolts that hold the fan pulley.
My only means of dis-engagement is to remove the V-belt.
Another probably easier option = I often see alternator pulleys on E-Bay and the like that have both the 8-rib plus a V-rib groove.
Be aware that there are several sizes of V-rib groove.
Cars and smaller engines are usually equipped with "A" size belts.
Most diesels and equipment have "B", which are larger at 5/8" wide.
I much prefer the "B" size.
You can get away with using an "A" belt on a "B" pulley, but not the other way around.
Old Apr 19, 2013 | 03:15 AM
grim's Avatar
anyone else mounted pulleys off the fan pulley? do u have any photos? or how ya do it? do u have to take off the fan and fan belt pulley?
Old Apr 19, 2013 | 08:07 AM
sooty's Avatar
ive got a zena welding system, ive got their accessory pulley mounted to the alternator, adapting the welder drive with a short-v belt, I adapted the alternator bracket to mount the welder on top when needed, at above idle rpm, I get 150 amps of power, the welder also doubles as a backup alternator. the fan clearance to the fan pulley dosent warrant much room for anything, without deleting the fan, so I went outboard.
Old Apr 19, 2013 | 11:40 AM
Gots_a_sol's Avatar
Another vote for a v-belt combo pulley on the alternator. I have mine driving a compressor for on board air.
Old Apr 20, 2013 | 02:18 PM
thrub's Avatar
I have a hydraulic pump mounted on the drivers side and a v belt running off of the fan. I had to get rid of the fan clutch to mount the kit that I have. The hydraulic pump has a clutch like an air conditioner. I tried getting rid of the engine fan and using an electric unit, but had trouble with the truck heating in the summer while towing. I also had to remove the oil filler and install a filler in one of the valve covers.
jesussaves
Jun 12, 2010 10:43 PM
vzdude
Jan 22, 2008 11:49 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
Reel Native
Jun 9, 2006 06:37 AM
lt11le
May 16, 2006 03:01 PM
