Ac
Old Jun 10, 2009 | 12:35 AM
archer2's Avatar
[QUOTE=97catintenn;2500619]did you replace the oriface valve aka the expansion valve?
Is the expansion valve still available?
Old Jun 10, 2009 | 06:40 AM
Exekiel69's Avatar
If I get the gauges, what should be the readings? If it comes to that I guess I'll have to open the system and see if there is anything I didn't remove plugging it.
I'll post back the results, thank You.
Old Jun 10, 2009 | 05:08 PM
Exekiel69's Avatar
Orifice tube was extremely dirty, no wonder it didn't cool but a little. I cleaned it well (it was new so I re used it) then I used My compressor to blow air trough the cooler and the condenser or evaporator I always forget which is which, then the lines and the accumulator too. I blew as much air as I could through all the system ( no money for cleaner fluid) and then some more, My compressor is a big one and works fast so I think I got a good amount of what ever was there if not all. I pulled vacuum for a couple hours and I'm checking every hour or so to see if it holds well. If yes then I'll refill and hope it works out.
Old Jun 10, 2009 | 06:53 PM
Field_boss_cb's Avatar
Guys our trucks don't have an orifice tube, they have an expansion valve. Without gauges it will be hard to diagnosis.
Old Jun 10, 2009 | 07:28 PM
Exekiel69's Avatar
Well after 8oz of oil refill, and 36oz of 134a it blows 20f cold is that good? It sure fells good to have My a/c back, last time I was driving through some bad weather and I didn't have any a/c so the defrost was no help to keep the fog down to a safe level and I decided it was time to give it a fix. Thank You all, I didn't get the a/c manifold gauge bc then I wouldn't have had enough for the refrigerant but I did have one of those idiot gauges (no #'s) that shows how close to high it is, what ever that means but I think I like the way it is now.
Old Jun 10, 2009 | 07:38 PM
If it is blowing 20 degrees, that would be super. i have never had one to get that cold.
Old Jun 10, 2009 | 08:00 PM
RollinCoalSmoke's Avatar
Field boss cb Exekiel69 has a Fummins setup. A Ford F350 conversion. Exekiel69 come work on my a/c's with it blowing 20 degrees you did something right. It's tough being young and inexperienced but you will make it, you keep trying more than I can say about most. But you got it working is all that counts. Good job and good luck.
Old Jun 10, 2009 | 08:08 PM
Exekiel69's Avatar
I have a temp gun I pointed it inside the air vent and it showed 27f outside and 20f inside the vent. I had it running for 30 minutes to make sure it was flowing well and it stayed at the same temp all this time.
Old Jun 11, 2009 | 06:05 AM
That explained the orifice tube. He should be able to hang meat inside that truck and it not spoil.
Old Jun 11, 2009 | 01:21 PM
gadget.35-06's Avatar
Fummins? Jeez, I hope that doesn't mean the Ferd freeks are calling us Dummins!
Old Jun 11, 2009 | 04:54 PM
Exekiel69's Avatar
It is only fair.
Old Jun 12, 2009 | 09:15 PM
samiam4's Avatar
Great you got low vent temps..
You NEED to check pressures. The sub-freezing temperature can lead to freezing which will destroy the compressor. Without pressures, I'd guess you have it overcharged.
M
Old Jun 14, 2009 | 07:48 PM
Exekiel69's Avatar
I'm going to spend the money on a guage set, so I won't have to worry on anything blowing in the future. Could someone tell Me what are the reading I should see on the low and high pressure side? Anything else I should do while at this?
Thank You.
