ABS/Parking Brake indicator lights on - No daytime running lights
Old Feb 8, 2013 | 12:38 AM
BuckyKatt's Avatar
The ABS and the parking brake lights lit up on dashboard.
The daytime running lights aren't working.
Any help, appreciated!
1997 Dodge Truck
Old Feb 8, 2013 | 12:55 AM
Guardrail's Avatar
Did you spin the wheels excessively recently?
Guardrail
Old Feb 8, 2013 | 07:34 AM
sooty's Avatar
abs module is behind glovebox, a single wire next to it can be grounded to access codes listed in the stickies
Old Feb 8, 2013 | 11:07 AM
j_martin's Avatar
Many items will light the brake warning light, which in turn will light the ABS light.
Common items are park brake pedal switch, vacuum switch, and balancing valve switch.
Old Feb 8, 2013 | 01:12 PM
Mark Nixon's Avatar
Originally Posted by BuckyKatt
1997 Dodge Truck
Since we're talking a 1997, which has a LOT that is different from a 1st gen, start with the fuses at the end of the dash and check the fuses in the control box under the hood.
Mark.
BigBore050
Mar 9, 2010 11:46 PM
getrdun
Nov 26, 2008 11:46 AM
alto22
Feb 8, 2007 04:58 PM
blownbanana
30
Mar 28, 2004 12:41 PM
fitzer
Jan 18, 2003 01:11 AM
