94-up exhaust system?
Old May 11, 2007 | 03:51 PM
edwinsmith's Avatar
I checked with my local exhaust shop and he says he can get a 4 inch system and install it for $450. The catch is it's for 94 and up. If I got the flange adapter for a 94 and put on my WH1C would the rest of the system fit?
Edwin
Old May 11, 2007 | 05:41 PM
dodgenstein's Avatar
The downpipe will come very close to the pinch welded seam wher the firewall angles to become the floor, if it clears at all. I have experimented with this some and I am currently running an HX35/14cm combo in a 91 with a Getrag. Out of 3 downpipes and 2 elbow choices I had, I mixed and matched to get about an inch of clearance, but I plan on something different soon. After the downpipe, you can probably get away with it if you let it hang down on a 2wd.
Old May 11, 2007 | 07:28 PM
edwinsmith's Avatar
I'm just wondering if the adapter on the left, if I added one to my system, would allow me to use a downpipe etc... for a 94 CTD 4 inch system.
Old May 11, 2007 | 09:28 PM
I had one like the one on the left, and 2 differen ones that clamp to a 1st gen type v-band outlet. Each was slightly different. There were subtle variations in angle/length. Also the combo I tried on my 93 W250/Getrag truck didn't fit on my 91 D250/Getrag. I don't know if it was the difference 2wd vs. 4wd or production variation or what. (Both were mocked up with the same turbo.) Sorry I can't be more helpful, but in 3 trucks I had 3 different fitments.
Old May 11, 2007 | 11:26 PM
ChevellePull's Avatar
Why don;t you roll with the Stan's kit? I have heard nothing but good things about it... Just a thought
Old May 12, 2007 | 06:33 AM
JD730's Avatar
That'll get you a downpipe that will fit properly, price should be close to what your looking at now. The problem with the 94 and up kit is the downpipe, it can be made to fit, but it takes some doing.
On a 4-wheel drive truck there will be a problem with the exhaust/transfer case clearance, it needs a jog in the pipe to make it around. 2wd don't have that problem obviously. Other than that is should work.
Old May 12, 2007 | 12:31 PM
Supernova's Avatar
I'm looking for an upgrade too and have been emailing the folks over at www.dieselpro.net. They're offering what they claim to be a true 4". Below is my email exchange with them. Not cheap, but that's always relative to me not necessarly you
http://www.dieselpro.net/productDesc.html?prod=3035
It is a true 4" mandrel bent exhaust system that does not have any flattened or crimped areas. The only area that is not 4" is where it connects at the turbo, about 1" long.
Thanks,
Sales Team
1-877-388-6552
www.AllTimeAuto.com
----- Original Message -----
To: AllTimeAuto.com
Sent: Friday, May 11, 2007 11:19 AM
Subject: Re: Exhaust Sale
Alright....can you answer if it's a true 4" or does it have reductions on the downpipe and over the rear axle that reduce to 3 - 3.5"? Thanks.
"AllTimeAuto.com" <sales@alltimeauto.com> wrote:
the sale is on the stainless steel kits. unfortunally the kit we have for your vehicle is aluminized an is not on sale.
DieselPro Extreme Exhaust System
(4 inch kit)
Part Number: D48993
Color: Aluminized
Est. Shipping: Usually Ships Same Day
Model Years: 1989 - 1993 Dodge 2500, 3500 Cummins Diesel 4 inch downpipe connects directly to turbo all bed and cab config Add D48993 to cart
$520.00
this is a true 4 inch kit there is a section about 1 inch long right at the turbo that necks down to fit on the turbo. but the rest of the system is 4 inch. this is the only true 4 inch kit on the market. the kit comes with the muffler. and the price can not be reduced to eliminate the muffler
Thanks,
Sales Team
1-877-388-6552
www.AllTimeAuto.com
To: sales@alltimeauto.com
Sent: Thursday, May 10, 2007 8:26 PM
Subject: Exhaust Sale
Hello, I noted your having a sale according to info on your website and wanted to inquire if your exhaust will fit my application and the cost.
I have a 1993 Dodge W250 (4x4) extended cab, automatic transmission with the Cummins 5.9 Diesel. I also am curious if your exhaust is a true 4" from the turbo back or does it have size reductions as some do that reduce 3-3.5". I don't need a muffler as I already have one planned for the install.
Thank you.
Extreme diesel performance made easy! 3, 4 & 5 inch Stainless Steel and Aluminized diesel exhaust for Chevy, Ford, Dodge trucks. We use BAND CLAMPS on our stainless!
[$49.95 - $626.00]
SALE
RiverRat2
Oct 15, 2019 10:59 AM
superdodge
Jan 30, 2010 07:16 PM
goin
Apr 27, 2003 08:45 AM
hvanflee
Feb 6, 2003 05:34 PM
