93 w250 dually front brake woes
Tried to change the pads today and my idiot friend broke off the head of the allen key. is there a way to get the caliper off and just use a new one? or do i have to get it drilled and tapped again.
You should be able to get that out. If it is preventing you from removing the retainer, you should be able to drill it down low enough to get it out. If you can't get a drill in there maybe a dremel tool would work. Was he turning it the wrong way or was it rusted in?...Mark
That depends on how clean you can get it out. I would try to get it ground down enough to get the caliper off, then take it down to a machine shop to get it out. I assume that the caliper is still on the truck, right? All that bolt does is keep the retainer from coming out, it shouldn't be that tight. Try spraying it with pb blaster and letting it soak for a while. I have pretty good luck getting broken bolts out, the most important thing is to drill it out enough to take most of the material, without messing up the threads...Mark
All you have to do is drill it down enough to get the retainer out, you should be able to do this without going too deep. Once it's off the truck it will be a lot easier to remove the bolt...Mark
got retainer out but now it looks like the caliper wont come off it moves up and down but not enough. My c clamp wasnt big enough to get around the caliper so i tried pushing on the piston with a flat head but nothing
What I do is use a carpenters flat bar type clamp, and clamp it directly on the disk. The piston is probably seized in the caliper. When the piston is pushed back, the caliper should come off. Try removing the brake line from the caliper. Were you able to save the threads in the broken bolt hole?...Mark
nope a buddy threw a bouncy ball right into my delicate area today as i was drilling and well you can figure out the rest. Pretty impressive shot i must say. also all i have access to is the screwdriver because although i am at a school for diesel mechanics no one has tools. also is the piston on the inside towards the engine or the outside , I am going in through the slot at the top of the caliper. sorry for the paragraph
