93 grill removal
Old Apr 30, 2004 | 10:33 PM
apache's Avatar
93 grill removal
Im trying to get at the A/C condensor/radiator? in the very front to clean the fins etc. How do you get at that booger? I see a couple screws in the balck center part and thats it. I must be gettin old!!!
Old Apr 30, 2004 | 11:02 PM
AlK's Avatar
AlK
I believe the 93 grill is the same as on the 92. Going by memory. The 5 philips screws that hold the top of the grill are easily seen when you open the hood, in the bottom slot of the grill there are 4 phillips screws, remove the signal lights and there is at least 1 philips screw on each side, you may also have to remove the headlights, but as I said I am going by memory, but then my memory could be going.
Al
Old Apr 30, 2004 | 11:58 PM
apache's Avatar
Thanks, Ill give it a wirl in the morn. I did see the screws on top, but dont see where there at on the bottom.
Old May 4, 2004 | 08:54 AM
RedWhiteDiesel's Avatar
Did you ever try simply using a high PSI air gun with the long extended end to try and clean it out? Thats what we always use at the shop whenever a vehicle comes in with a radiator/condenser thats plugged up with bugs and such. Make sure you wear glasses if you try it, stuff flies everywhere!
Old May 4, 2004 | 08:57 AM
apache's Avatar
Yeah, it just seems the crud wont move. Ive hosed it out a couple times as well and still looks boogered up.
HUNTINNUT
Jul 27, 2013 11:40 AM
Gumby
Dec 1, 2011 09:05 AM
TXlilbro
Sep 15, 2010 04:11 PM
trik396
Jun 1, 2008 07:04 PM
ram 2500
Mar 3, 2008 07:41 PM
