92 D250 auto no o/d what next??
Old Jul 24, 2011 | 08:49 PM
cknoop's Avatar
10 Year Member
my brother has a 92 D250 2wd auto wont shift into o/d I rewired tps with Raidio Shack pointeneometer nothing checked wires at plug on tranny one hot 12v other not.. changed o/d solinoid mounted to side of valve body still no o/d even applyed ground to wire going to solinoid nothing what is going on?? hooked up code reader only cone is 24 TPS voltage high-low depends on where you pos. pointeneometer.. any ideas similar experances thanks for any info
Old Jul 24, 2011 | 09:46 PM
whosdunit's Avatar
My problem was in the steering wheel , pulled the horn cover off !!!! Some "po" had cut all the wires and took the 4-way plug, go figure. Re soldered the wire s up to 4-term., plug tryin to find donner pulg now.
Old Jul 24, 2011 | 10:13 PM
YOu had to do that to fix the overdrive or cruise control? I didn't know any of those wires behind the steering wheel had anything to do with Overdrive
Old Jul 25, 2011 | 07:46 AM
whosdunit's Avatar
It was the cruse, sorry about the confusion.
dzl_damon
May 27, 2008 03:10 PM
banzaitoyota
Oct 13, 2003 01:11 PM
banzaitoyota
Oct 9, 2003 11:15 PM
banzaitoyota
Sep 29, 2003 02:34 PM
greatwhite
Jun 26, 2003 07:21 AM
