92(12valve) 46rh(a518) heat exchanger
Do some research on trisodium phosphate to flush your system. When I was a kid we used 100% tap water for years in my old Ford van. (I was in SWFL.) When it came time to move up north we put TSP in it and drove it until all the calcium build up was gone on the radiator fins. Flushed it real good and ran the anti-freeze mix in it. See if you can find some water pump lube.
Alright I think I'm gonna try out the restore plus first since Cummins recommends it and see what happens it has a mild acid-based chelating cleaner seems a bit heavier duty compared to the regular restore product which is just alkaline based.
Zerex? It's a brand of Valvoline which was based here in Ashland. NAPA sells it so that's what I use. G5 is supposed to meet the Cummins specs. I've run it in my Cummins for close to 20 years and in everything else for longer than that. I mix 50/50 or 75/50 (oh lordy let's not go there again).
autocross72
Jan 2, 2009 05:18 PM
