91 speedo doesnt work
Old Apr 6, 2015 | 02:23 PM
Philip's Avatar
bannerd bad cab grounds can cause jumping. A bad VSS plug can cause jumping. A bad connection anywhere in the VSS circuit can cause needdle jumping.
Just laying under the truck with the VSS on a drill does not give you air flow movement of the harness to show a bad connection.
The PCM reads the VSS signal for CC. It also supplies the 5 volt power feed for the VSS.
bannerd I went threw this yesterday on my truck. After about 5 hours I had a working speedo and CC agin.
Old Apr 6, 2015 | 02:50 PM
RamGuy84's Avatar
Try some glue and see if that help's
Old Apr 6, 2015 | 11:23 PM
peddlebike's Avatar
Originally Posted by bannerd
I tore my vss off my truck this weekend. Hooked a drill to it and it is working fine. Wondering if the square hole is rounded at the top just enough to cause the needle to jump around? Any suggestions on how to fix that?
I also have a '91 W250 .... Speedo quit working a year ago.
The gear drive from the transfer case worked ...
The reduction gear worked ....
The drive was rounded ..... sleeved it with some thin vinyl, buttoned it up, and it works very smooth. No needle jump like before.
Just put some odometer gears in ..... try everything tomorrow.
mytrucksaslug
Sep 14, 2006 06:38 AM
coadman
Jul 10, 2006 07:22 AM
golddusters5703
Jan 5, 2006 05:03 PM
trex
17
Dec 11, 2005 10:03 PM
bigbaddiesel
Oct 30, 2002 01:08 PM
