'91.5 Dana 70 parts
'91.5 Dana 70 parts
Hey guys. I'm gonna be freshening up the rear axle in the '91.5 to swap into my '90. I'm gonna service the differential and go through both wheel ends and replace everything just so I know it's all new. Wheel bearings, seals, wheel cylinders (might go for the GM "upgrades" or the 1 1/8" bores), drums (maybe), shoes, all the hardware, etc. I really don't have a budget as most of these parts will be fairly inexpensive. I'm looking for some guidance to all the right parts. I've been looking on Rock Auto and, of course, they have a few different manufacturers of parts to choose from. I wanna get good stuff. Thanks in advance, fellas!
So you are freshening up a 32-spline Dana 70 to replace a 35-spline Dana 70? Just thought I'd point it out if you hadn't realized. (axle bolts = 32-spline; axle studs & nuts = 35-spline).
I started with just checking my brakes, but found some of the hub bearings pitted, and play in the carrier bearings. Ordered a Lockright too (from PORC.) My spindle nuts are the nylock type - all beat to snot from being removed with a hammer and chisel. Ordered some D60 front spindle nuts. Gonna see how that works out. Get hub seals, axle flange gaskets, and I like to use a diff cover gasket.
Ordered all from Rockauto. I'm not so picky about the brands so much as get it all from the same warehouse to save on shipping.
Its almost a must to go with Timken bearings. They were the OEM supplier. Dont believe that crap on the internet about National bearings being the same. Timken Timken, Timken. You should have a 32 spline Dana 70U
I haven't looked in a while, but there was an E-Bay vender that had complete bearing kits, gaskets, seals, clutch-packs, the whole works, all for one money, WITH TIMKEN BEARINGs.
His prices were reasonable for everything that you got.
If you can't find the good double-nut/folding-tab-lock-washer wheel-bearing nuts in an older Dana-60 or so at the junk-yard, here is a place that sells them new :
http://quad4x4.com/Dodge%20Rear%20Axle.htm
Carry on.
Carry on.
I just got a 3.07 rear re-bearing'd and clutch-ed from a local supplier called The Gearbox. Got mail-order/internet prices and the axle kit was entirely Timken bearings. They took all the OE shims; pre-loads, depth and backlash all perfect...no way I'd do anything else.
cheers,
Douglas
What will happen eventually is that, due to 99% of consumers buying by price, such quality concerns as TIMKEN and SPICER will lose so much business that they will no longer be able to stay in business.
They will then sell their NAME to some cheapy company and we will then be buying only the name and not getting the quality.
Another piece of America gone.
Carry on.
Carry on.
There is TONS of useful info in the parts catalog! I can only hope some of the parts I'd like to have are still available. I was hoping the Dana 70 service manual would cover the service and/or replacement of the wheel bearings but I believe my FSM covers that so I'll take a look in there. I've never done the wheel bearings myself.
), so that would be best, IMO...Mark P.S. Timken for bearings
