89-90, which high pressure line is on top?
Old Aug 3, 2018 | 04:48 PM
B Miller's Avatar
I numbered the 6 high pressure lines prior to removing, but did not note which one was on top
going over the head between valve cover 2 and 3.
Also between valve covers 4and 5?
That would be high pressure lines 2,3,4,and 5.
The reason for all of this is that I have been running 100% biodiesel for the last 12 years
and all of a sudden my engine is running rough and smoking.
First took out the injectors and checked the spray pattern and pop pressure which was fine.
Next removed the injection pump, but had trouble with the fuel supply line going to the top of the injection pump
and the high pressure line number 5 leaving the pump.
The two connections were like they were welded together
Had one hell of a time for a couple days.
Could only work from 6:15 to 7:30 AM each day because of the sun blinding me and the heat.
Old Aug 4, 2018 | 10:04 AM
nonrev's Avatar
10 Year Member
Here ya go, when I take my lines off I do not take the clamps apart so they come out as a set of 3, makes it way easier
lines 1,2,3
lines 4,5,6
Old Aug 4, 2018 | 12:47 PM
B Miller's Avatar
NONREV
Your two pictures are of a later model.
It has the stud on valve cover number one for putting on the Cummins name cover.
The 89 and 90 did not have that.
Old Aug 4, 2018 | 06:31 PM
nonrev's Avatar
10 Year Member
B Miller, sorry about that here is the correct set off my 90
lines 1,2,3
lines 4,5,6
Hope it helps
Old Aug 5, 2018 | 04:44 AM
B Miller's Avatar
Thanks NONREV,
Just what I was looking for.
isb07
Nov 18, 2009 05:12 PM
CTD NUT
Off Road / 4x4
Oct 20, 2007 01:57 PM
