6.7 & 5.9 VE Questions
I have some questions regarding the differences and similarities between the blocks, strokes & valves.
On the 6.7 engine,
Does anyone know what dimensions changed on between the 5.9 & 6.7?
If the valves are larger, could the 6.7 valves be fitted to our heads after a major porting job?
Is there enough material in the 5.9 block to machine and accept 6.7 cylinders?
How much longer is the 6.7 stroke than the 5.9?
This thread got me thinking:
On the 6.7 engine,
- the bore increased
- the stroke increased
- did the valves increase in size
- and are the rockers the same or would they need to be changed if using some 6.7 parts
HTML Code:
https://www.dieseltruckresource.com/forums/6-7-liter-t274353.html
yes thank you for reminding me. To better focus my question, the actual size of the valve (air or exhaust) increase with the displacement. Could our heads be machined to accept 6.7 intake and exhaust valves or are the valves on the 6.7 the same size as the valves on the CR 24-valve 5.9?
There are many machine shops out there that will put what ever size valve you want in your 12v head, custom valve sizes can be had from mild to wild. Just put intake valves all the way across your head. Or call Manley or Ferrea valves and have some custom made. Our tiny bores will only let us go so big, shrouding becomes a major issue after a certain point.
Will be putting a p-pumped 6.7 into my first gen towards the end of the year. There are a few issues to consider. Connecting rods, and front cover issues along with head/p-pump interference. All have solutions. Should make a nice modest hp daily driver.
Make sure you take a lot of pictures and do a good write up I've been considering doing that for awhile I just haven't gotten the money togaether and done all my research yet but a write up would be awesome
Mark Hodowanec
Feb 26, 2006 08:35 PM
mdq
Jan 16, 2003 04:59 PM
