47RE questions
Old Mar 15, 2010 | 09:41 PM
Clyde Roper's Avatar
47RE questions
Ok, has anyone ever swapped one into a 1st gen, and what did it take to make it all work, or should I forget the idea all together
Old Mar 15, 2010 | 09:54 PM
The_Head's Avatar
good question. Probably has to do with the electronic control part of the deal.
Old Mar 16, 2010 | 01:23 AM
rockjeep73's Avatar
manual valve body is the simplest way.
Old Mar 16, 2010 | 11:13 AM
I have a good 518 in the truck now, but with a weak convertor, picked up the RE with low miles, for a good price. I have changed VBs before, but have no clue on whats involved with changing the OD unit out. How big of a pain is it to do, will it unbolt from the main case, or do you have to take the whole trans apart to do it??
Old Mar 16, 2010 | 11:26 AM
The_Head's Avatar
JD730 would know.
It would be nice to have another alternative to a 47RH. There are lot's more 47RE's around. Even some 3rd gens came with them.
Old Mar 16, 2010 | 11:41 AM
Fred Swanson's Avatar
manual valve body, or a stand alone controller. Either option is typically a deal breaker on a 1st gen due to cost.
Old Mar 16, 2010 | 01:13 PM
JD730's Avatar
Originally Posted by The_Head
JD730 would know.
The trans I'm running in the truck right now started out life as a 1996 47RE. Like TXS said, you need a valve body, OD piston retainer. You can switch the whole overdrive unit or swap the guts around, which is what I did.
Don't forget you need a spacer to bolt a NP205 to a 47RE.
Old Mar 17, 2010 | 11:07 PM
why the spacer, if I use the 518 OD unit??
Old Mar 18, 2010 | 06:04 AM
JD730's Avatar
You need a spacer if you run a full out 47RE with the RE overdrive unit, if you put a 518 OD unit on it you are making a 47RH.
Old Mar 18, 2010 | 09:47 AM
Ok, that makes more sense. Now, if I were to use the 518 OD, and valve body, how would I go about controlling the lockup? or would I need the VB off of a RH to do that?
Old Mar 18, 2010 | 02:34 PM
Greed 93's Avatar
RH valvebody is needed
Old Mar 19, 2010 | 11:31 AM
yeah I will just toggle it, but first I have to get to that point lol.
Ok, so next question? What can I use the VB out of, other than a 47rh from a diesel? Will one from a gasser v-8 work? And if so does it need to be modified in any way to make it work right?
What a pain, wish I had the money to just have a good RH built, and not have to piece and parts this one together
