4 inch lift kit and the drive shaft is to long ????
Old Dec 9, 2008 | 05:21 PM
roxxx's Avatar
the lift is in front and rear and the truck is on the ground only to find out the back drive shaft is to long ... has anyone else ever had this type of issues
The lift is a full spring kit 4 inchs front and rear Skyjaker
thank you
Old Dec 9, 2008 | 06:01 PM
feveree40's Avatar
the front driveshaft was too short, but that doesnt help you. Are the rear springs on right? The eye should wrap over top of the leaf on the front, under the leaf on the rear.
Old Dec 9, 2008 | 06:21 PM
roxxx's Avatar
I will be looking tomorrow but i think they can only go on one way ,with the shim pointin to the front of the truck
Old Dec 9, 2008 | 06:25 PM
feveree40's Avatar
yep, that should be right unless skyjacker put the shims on backward.
Old Dec 9, 2008 | 06:32 PM
roxxx's Avatar
ohhh god i never thought of that
Old Dec 9, 2008 | 06:45 PM
SmokemS's Avatar
good ol skijacker
Old Dec 9, 2008 | 09:01 PM
Checkmate's Avatar
so is your rear axle pushed way forward or something ??? When I read the title I thought you did a shackle flip or something
Old Dec 9, 2008 | 09:14 PM
roxxx's Avatar
nope no shackle lift and the tire and axle are centered properly that's what we cant figure out (it was a full spring replacement ) and the loops are on the front going over top
Old Dec 9, 2008 | 09:29 PM
Checkmate's Avatar
You are talking about the stock shaft right ????
Old Dec 9, 2008 | 09:30 PM
DNRCustoms's Avatar
That just doesn't make sense.. Take some pics... Something has got to be installed wrong... No offense.. I'm no geometry expert, but when it goes up shafts get shorter!!
Old Dec 9, 2008 | 11:03 PM
roxxx's Avatar
yep i am pretty sure the drive shaft is stock but i am starting to wonder i know the front isn't
Dnc...
I know that's what I thought it seems the pin is to far forward no offense taken i have service calls in the morning but going to the shop in the afternoon i will take some pictures
Edit really weird because when it was full droop the drive shaft was way to short
lol it also could be just skyjacker oh and it doesn't sag .... so maybe i did get the wrong springs
Edit part numbers for the kit http://skyjacker.com/products/produc...tail/?id=54963
Old Dec 10, 2008 | 08:31 AM
Trebor's Avatar
I just went out in the rain and took a quick measurement off a frame.
From the front spring bolt center on the main leaf to the center bolt measures about 24 inches. From the center bolt to the rear spring mounting bolt measures 28 inches. The rear axle isn't centered on the distance from the front to rear spring mounting bolts.
Old Dec 10, 2008 | 08:50 AM
roxxx's Avatar
Super I was going to ask some one that (and thank you very much ) I was just on the skyjacker web site looking at the pic of the springs there now I know they are ref pictures but have a look are these the same as what others have this is what i got in my kit same looking ones as the ref pic 4 inch
Attachment 25114
Old Dec 10, 2008 | 02:37 PM
Evil Ram's Avatar
it happens, one of my front springs had it backwards when i bought them
Old Dec 10, 2008 | 03:31 PM
DNRCustoms's Avatar
Well, I just went and measure my stock springs and they were 24" from center pin to front eye and 28'' to the back...
