366 spring issue solved
Old Apr 3, 2010 | 12:26 PM
fast59's Avatar
Ok so i thought i would post what i had done to cause confusion of my spring install.I had all kind's of wierd issue's going on no matter what i did it just didnt work out.So i decided to pull pump top off again and start from the beginning when i loosened the bolt's i heard a snap,now it was'nt the sound of metal snapping but it felt like something snapped back against the housing when i lifted the top off i realized what i had done the arm for the power screw had been jammed into the top of afc housing,when i tried adjusting spline location and could'nt get to idle properly that's when i figured the power screw was'nt in far enough so when i turned it in farther and it bottomed out i thought it was the screw bottoming against the afc housing not the arm.Now that's a lesson learned and i have to say it was worth the trouble truck is awesome with it in now and i learned something new.
Old Apr 3, 2010 | 09:40 PM
TIMMY22's Avatar
Richie can now breathe a sigh of relief, he had 37 complexes since this happened.
Glad you figured it out, you probably couldn't get it to do that again if you tried.
BurrisWill
Jan 25, 2009 08:23 PM
KRB
Nov 27, 2007 03:34 AM
b1eric
Jun 12, 2007 08:46 PM
Mike T.
Feb 3, 2007 07:19 PM
vinny
Nov 15, 2005 10:55 AM
