3" in/out muff needed
I've been searching the site and online and all I see is 4-5" mufflers for our truck. Did I screw up that bad by installing a 3" system?
I want a 3" in/out to reduce the sound of my striaght piped system that exits in front of the rear axle.
Does anyone know who sells one for around 100 bux?
aero turbine will probably have what you're looking for. their $50 more than you probably wanna spend. but here's a link to their 3" Aero Exhaust. you could maybe try heartthrob exhaust... Hearthrob Exhaust
I looked at the areo one and thought, what?? It's only 8"s long, that thing won't work! But after reading the specs, it's really 20"s long.
I should have just bought the 4" inch kit when I needed my exhaust replaced instead of trying to save money.
Now, the replaced/new downpipe (130), existing 3" pipe (200), and now the muffler (150)...I really did screw up. $480 which is the same is a complete 4" system or close!
200 was the pipe, bending it, and labor from the turbo back. 300 to go over the rear axle, and in my small town only one shop could do it. sort of. The flange at the turbo failed, so I've ordered a new flange, and now I want to quite down the system.
So, this is how my charges added up.
I live in a small town. Mighty Muffler or whaterver shop owner came out to look my exhaust after it had rusted in two. At this point, I had the exhaust from the downpipe (DP still attached to turbo) back sitting in the bed of the truck to be re welded. The owner got mad and told me that it didn't just rust out...I had cut the catalytic coverted out and wanted him to weld it back together illegally!
So, even at 200, I had a hard time getting it done.
I think it's aluminuim, I had another shop order it for me. I think he gave the stick to me for free.
Crazy matt, it maybe...maybe i've been listening to it while it was disconnected for the turbo too long. It happened 200 miles into a 700 mile round trip. I was safety wiring and roping it back together at different exits along the way! It wasn't a fun trip.
[QUOTE=97catintenn;2526341]I live in a small town. Mighty Muffler or whaterver shop owner came out to look my exhaust after it had rusted in two. At this point, I had the exhaust from the downpipe (DP still attached to turbo) back sitting in the bed of the truck to be re welded. The owner got mad and told me that it didn't just rust out...I had cut the catalytic coverter out and wanted him to weld it back together illegally!QUOTE]
Either I missed something (in the story) or that shop owner is smoking some serious crack ... dodge diesels didn't have cats until 04.5 ...there's no freaking way a diesel had a cat in 91 ... go kick that guy in the ***** for either trying to screw you over or for being an idiot, either way ... same punishment.
You might consider a donaldson 4" in / out from airflo.com and just use 3"-4" couplers to flare up to 4" and back to 3".. Or go all the way, step up to 4" at the muff and buy a 4" 90 degree elbow from airflo.com and bolt n go... cheap too
Yah, and I still had the big ole resonator there in the pipe!
So, what's my parts list going to be?
3"OD to 4"OD adapter
4" Donaldson Resonator
4"OD 90* bend
Is the Donaldson going to be 4" ID on both sides?
4"OD 90* bend
sounds like that's all you'd need. the muffler should be a 4" ID. being a slip on, don't forget exhaust clamps unless you plan to have it welded. you could have the adapters welded to the in and out of the muffler and just clamp the adapters to the rest of the 3".
where are you buying your 3"? is it stainless? i got my 4" done for about $160
