1st time pulling
Old Jun 11, 2007 | 07:06 PM
MDLP412's Avatar
1st time pulling
what are your thoughts on pulling a 8.5K sled on a nearly stock 5-speed?
Old Jun 11, 2007 | 07:30 PM
dieselJon's Avatar
Have a lot of money for a clutch after you destroy this one
Old Jun 11, 2007 | 07:41 PM
MDLP412's Avatar
what would be reccomended for doing this kind of stuff? you say a new clutch dual maybe? obviously alot more power... any other mods to the drivetrain? any help plz! im hoping to pull end july
Old Jun 11, 2007 | 11:02 PM
1stGen545's Avatar
4Low 2nd gear give it a little fuel and come off the clutch and when you start moving good put it on the floor. Most of the sleds are closer to 25-30K, my truck is 7.6K. If it starts bouncing push in the clutch or you WILL brake something. No offense but you dont make enough power to need a DD A good South Bend is more than enough even with a lot of mods. Some bars like these will also help keep it from jumping. Also if there are few or no ruels you want to get your hitch as tall as you can it will pick up on the front of the sled and help carry it down the track and give you more traction.
Old Jun 12, 2007 | 01:07 AM
BearKiller's Avatar
If you are tired of your truck and can afford another, then sled-pull to a fare-the-well.
Otherwise, it shows a lot more good sense to enjoy the pulls from the bleachers, and keep your truck intact and your dollars in your shirt pocket.
One slight mis-step, in a hard pull, will show itself in weakened/broken pieces, even years down the road.
Old Jun 12, 2007 | 07:19 AM
Cowboy_Customs's Avatar
As far as drivetrain mods go, if you want to do well, U need a locker in both front and rear axles. Full lockers not just clutch lockers. Some organizations require driveshaft hoops to keep it from hurting/destroying anything if/when a u-joint goes pop. Traction bars.
Depending on how serious u want to get a duel disk is a good idea, however if its only a couple times a year (like local fairs) just find a real beefy single. Call south bend n discuss options with them.
mullercarl
Competition / Pulls / OffRoad
45
Mar 19, 2007 10:10 AM
thewished
Mar 2, 2007 12:54 PM
NeedMoPower
Jan 8, 2007 07:01 PM
rockjeep73
14
Jul 9, 2006 06:57 PM
stillsmokin
Dec 21, 2005 05:06 PM
