1st Gen Vs 2nd Gen Motor Mounts???
Old Mar 2, 2021 | 10:03 AM
k5blazer72's Avatar
Hey guys! I am swapping a 12v from a '94 Ram into my 1974 Dodge RV. If I use the 94 engine mounts I will have to fab up some new mount tabs to the RV frame (which is doable for me). I'm under the impression that 1st Gen engine mounts (stands?) will bolt on my engine block and will probably bolt onto my existing RV frame mounts (its a Dodge M300 frame).
Any common problems with the 1st Gen mounts? Would it be worth it for any reason (durability, vibration, easy to buy/replace???) to use 2nd Gen mounts???
Here's a pic of our transplant patient!
Old Mar 2, 2021 | 01:28 PM
u2slow's Avatar
Does the existing gas engine use side mounts? If so, the 1stgen route is by far the easiest.
Old Mar 2, 2021 | 03:57 PM
k5blazer72's Avatar
I’m not 100% sure what you mean by “side mounts”, but I’ll take some pics and post them. It’s a 1974 with the original 440 BB engine and TF 727 transmission.
Old Mar 2, 2021 | 05:19 PM
u2slow's Avatar
Mounts would be on either side of the engine. The other style... would be a single mount under the crank balancer area, and then 2 mounts on either side of the bellhousing.
I don't know what setup a '74 M300 chassis uses.
On my '84 ramcharger, the 318 used side mounts, and 1stgen cummins mounts bolts right into the same crossmember locations.
slicknapier
Feb 2, 2011 02:47 PM
ryan10
Nov 10, 2009 05:11 PM
lews930
Aug 15, 2009 09:32 AM
lews930
Aug 14, 2009 04:20 PM
MDLP412
Feb 3, 2008 11:46 AM
