1993 350 cummins ext cab single rear wheel??
Old 09-16-2013, 10:43 PM
gyman98's Avatar
Is the sticker still on your door jamb? It should say
Old 09-16-2013, 11:08 PM
dieselluvr's Avatar
My first first gen was a W350 non dually. The rear leaf pack will have one more spring than the W250's
Old 09-17-2013, 07:04 PM
JasonTx's Avatar
here is door tag
and pic of truck
http://www.flickr.com/photos/93591600@N03/9792346683/
http://www.flickr.com/photos/93591600@N03/9792258955/
Old 09-17-2013, 07:12 PM
simplysmn's Avatar
215's came on DRW not SRW? 10.100 gvw is DRW
Old 09-17-2013, 07:15 PM
JasonTx's Avatar
for sure??
Why is it decoding a single rear wheel?
Old 09-17-2013, 07:16 PM
simplysmn's Avatar
When I checked it it showed DRW
Old 09-17-2013, 07:19 PM
gyman98's Avatar
Look at the sticker, it has a X near dual
Old 09-17-2013, 07:20 PM
gyman98's Avatar
Originally Posted by JasonTx
for sure??
When I check it shows DRW as well
Old 09-17-2013, 07:22 PM
simplysmn's Avatar
It's a clean truck but sorry it use to be a DRW truck somebody has swapped bed and rear axle around is all . doesn't make it worth any less in Value . I mean if you want to pick it apart grill has been changed also . so what else has been changed is yet too be seen .
Old 09-17-2013, 09:52 PM
torquefan's Avatar
Yep, the sticker confirms it as a dually, by both the GVWR at 10,100 LBS, and the X by the word "dual". Another small clue is that the truck has cab lights, which all duallies are required to have by law, due to the vehicle's width. From the factory it would have also had three red identification lamps on the tailgate.
True, many SRW trucks came with cab lights, but all duallies did.
Old 09-18-2013, 09:00 AM
1STGENFARMBOY's Avatar
Yes that door tag is for sure from a dually truck
Old 09-18-2013, 09:27 AM
93-12Smoke's Avatar
Could have been a cab swap. Wouldn't the front hubs have to have been changed as well to swap too single wheel? My bet is it was a cab swap onto an already single wheel truck.
Old 09-18-2013, 11:35 AM
simplysmn's Avatar
changing the hub's is easy the amount of work done too that truck makes you think maybe it was wrecked at 1 time and not turned into insurance company and just rebuilt ?
Old 09-18-2013, 11:43 AM
93-12Smoke's Avatar
Not saying it's hard, just odd to swap from dual wheel yo single. That's a lot of work to downgrade.
I'm with Simplysmn, especially after seeing that aftermarket grill. Check the motor date and compare it to the build date.
Old 09-18-2013, 12:40 PM
JasonTx's Avatar
well thanks a lot guys.
I really really appreciate the help
thanks again
Quick Reply: 1993 350 cummins ext cab single rear wheel??
