1990 front axle nut *** help.
What happens is Tom Dick and Jill use chisels and what-not to loosen/tighten the nuts until they get all buggered-up.
If you can't coax it off with the socket, then carefully walk it off with a DULL cold-chisel; use a sharp one and it will dig in deeply, making a bigger mess than you already have.
That is true, but we are adjusting bearings, not tightening the flange on a hydrant; there is no way to judge proper pre-load when whacking on a chisel with a hammer.
Harbor Freight sells a double-ended spanner that works for less than seven-bucks.
njmaier
17
Oct 9, 2006 05:10 AM
CRSmith
Dec 4, 2005 09:51 AM
