150# Valve Springs
Old Mar 11, 2009 | 05:37 PM
cedardiesel's Avatar
150# Valve Springs
How would my truck perform with these I'm converting over to P-pump and putting governor springs in it and looking to get bout 350-400 hp after swap I found these 150# springs on Industrial Injection's site for sale for 155.00 and tought that ain't bad. So would these be too stiff or would I be fine?
Old Mar 11, 2009 | 08:15 PM
Probably going to wipe the lobes off your cam.
I assume you are doing a 4k kit on the P-pump? The "60 psi" springs will be fine for that, the 150 # springs are for a wild cam and I'd consider them a race only part. For a 3k kit no spring upgrades are needed.
Old Mar 12, 2009 | 10:49 AM
Ok thanks that was what i was wondering anybody else got in put
Old Mar 12, 2009 | 01:36 PM
crewcabxlt's Avatar
Daves advice right on for springs. dont go with 150 lbs. a 350 hp properly built ve pumped truck runs better than a 350 hp p-pumper from my experience. variable timing in the ve is one reason.obviosly for 500+ hp go p-pump! plan on lots of supporting mods required to use the power however.
Old Mar 12, 2009 | 01:42 PM
peobryant's Avatar
Not from my experience... When my brothers truck was around 350rwhp, (a long time ago..) it ran great. However, if you build the P-Pump truck to 350rwhp the "right" way, than it would run just as good if not better than a VE truck. The reason VE trucks probably run better at 350rwhp, is because you have to upgrade a lot of things to get to that rwhp level. With a P-Pump, a couple of mods will get you there, without having to upgrade a lot of other things.
Having said that, a 350rwhp VE will still be faster than a 350rwhp P-Pump.
Old Mar 12, 2009 | 01:54 PM
Bob Beauchaine's Avatar
I remember a post by Old Smoky saying that "VE" stood for "Very Efficient". At close to 400 RWHP I still see 18.5 MPG city and 22+ MPG highway.
Bob
dodgediesel
26
Nov 2, 2008 12:20 PM
53 willys
23
May 19, 2008 06:14 PM
curts99
Feb 14, 2008 12:09 AM
heavyJ
Oct 25, 2007 09:08 AM
Ramtuff06
Aug 21, 2007 06:21 AM
