12v 2-stroke oil adding question
Old Apr 20, 2010 | 07:58 PM
natwestbrook06's Avatar
Question 12v 2-stroke oil adding question
I have a question, is there a way to add the 2-stroke oil to the fuel in-line like the two-banger 50hp johnson does in my boat? all you do is make sure the resivour has oil in it or fill it when the light goes off. I know the fuel delivery on the outboard is much slower flow to the engine than what is in my 12v, but there has to be a way to add it "pro-bono" if you will, than pouring it in every time. ? ? ? ? ?
Old Apr 20, 2010 | 08:08 PM
TIMMY22's Avatar
Open the cap in the cement at the diesel shop, dump it in, start pumping.
Other than that, I think it would cost more than it's worth for an injection system.
Old Apr 20, 2010 | 08:09 PM
thank you for the simple answer.
Old Apr 20, 2010 | 08:12 PM
PatrickBoyle's Avatar
I think if you injected it into the fuel line the concentration would be higher than you need, unless you had some way to meter it. Ideally you want to have the 2 cycle oil mixed evenly with the diesel, that's why a lot of guys put the oil in before they fill the tank.
Old Apr 20, 2010 | 08:16 PM
true, it was just something that popped into my head when the oil light went off on the boat the other day. probably the second time I have added oil to it since I got it in 2000.
Old Apr 20, 2010 | 08:57 PM
dzl_damon's Avatar
I think the benefit is from lubrication as it goes through your injection pump. I'm not sure of any benefits of increased cetane, etc like the other fuel additives claim. If it was just injected into your supply loop on the suction side, part of that would recirc to the tank and make the oil oil concentration more and more.
Ya, just a bit at each fill up should be fine! I buy the cheap walmart outboard gallon jug, then put them in some smaller containers I have around that are "about right" for what I add to the tank. Throw a few in the tool box so you don't have to mess around with the gallon each time.
Old Apr 21, 2010 | 11:01 AM
GasganoFJ60's Avatar
1 oz per gallon is what I usually do.
So its about a quart of oil for every tank.
Old Apr 21, 2010 | 11:14 AM
dzl_damon's Avatar
sounds smoky!
Old Apr 21, 2010 | 11:21 AM
whosdunit's Avatar
I have a 91 F250 w/ 264,000 on it , i started using 1 qt. per. tank of diesel about 15 yrs., ago . I ONLY DO IT ABOUT EVERY 3RD., tank now ,i get from 17 to 22 mpg hwy., (68 mph., gets the best mpg.). I didn't know if it would be ok in my 91 d350 ,soooo what you guys say ....ok?,or not?
Old Apr 21, 2010 | 11:28 AM
whosdunit's Avatar
I forgot to say ------i was using cheap ,cheap,cheap trans. fluid. No certain brand.
Old Apr 21, 2010 | 11:32 AM
Id say stay away from the trans fluid and go with 2-stroke oil instead. Its designed to lubricate AND burn.
Old Apr 21, 2010 | 11:34 AM
Originally Posted by dzl_damon
sounds smoky!
On 2-stroke oil I really dont notice much of a difference on amount of smoke.
WMO on the other hand...
Old Apr 21, 2010 | 11:56 AM
lenuelmp23's Avatar
What benifits are there to using 2stroke oil in your fuel i have never heard of this? you have peaked my intrest. How much should i use and what does it do?
Old Apr 21, 2010 | 12:10 PM
roxxx's Avatar
Why would you just dump it in the tank
Old Apr 21, 2010 | 01:37 PM
1STGENFARMBOY's Avatar
I use 20 oz of walmart two stroke boat motor oil per tank don't no that it smokes any more because i have bad fuel haze, but i like the idea of lubricating my I/P a little more.
