12 Valve Renovation
12 Valve Renovation
Hey all,
I'm new to this site but though I should come share some cummins love. Along with my '99 4x4 24 Valve, I am doing a complete frama off rebuild of and old 1985 Dodge 4x4 W350 Crew Cab Forestry Truck. Right now it's stripped to the frame, and I just got finished painting it (the frame). The next step is putting in my donor 1992 cummins intercooled engine. It's currently sitting in my garage because I just put a fresh coat on it as well. It runs great but my question is, are there any seals that I should go through and replace right now while the engine is off, or sensors, or anything else? Only the crucial ones because I am on a budget and I'm not doing a complete rebuild. Thanks!
You might do the oil pan gasket as well. IMO, replace any and all seals/gaskets/sensors that you can while its out and easy to work around.
Keep us posted on the rebuild/conversion.
Ive had the idea in my head for about a month or so now of getting either a quad-cab 1st gen or a late 80's model 4-door Chevy and dropping a 12v, GearVendor, and a high rear end and making just an all out high-MPG highway cruiser. Cant wait for it all to go together...
The first post is the sticky, thats where all the good stuff is. there's days of reading in there. If there is anything else you need to know then ask and someone can send a scan of a factory shop manual or something. The haynes manual is about useless.
Oh and welcome aboard.
Rear main, valve covers (run the valves while you're in there), front crank seal and front cover (do the KDP while you're in there and tighten the timing case bolts) and maybe the pan if it's leaking since it's a PITA to change once the engine is in the truck. That should cover it.
Ok, finally the engine is ready to be dropped in the frame and the cab is next. I have replaced everything we talked about (with the addition of the rear main housing..broke that on accident...and a new thermostat). Here are some before and after pics:
before
after
before
after
the tires i think are 32s I'll check later.
the rims are stock for now,but i have some aluminum ones coming .
im keeping the truck stock height because its going to be a tow rig for my rock crawler.
