12 valve engine stand....
Old Feb 7, 2018 | 05:31 PM
edwinsmith's Avatar
Originally Posted by NJTman
Here ya go, Edwin. Made just for you...
Old Feb 7, 2018 | 06:12 PM
rotflmao......
Old Feb 8, 2018 | 05:12 PM
OVERTORQUED's Avatar
10 Year Member
Those will be fun when you trip over them. But then you're probably not as clumsy as I am.
​​​​​​​Anything to keep me on my toes!
Old Feb 8, 2018 | 05:30 PM
10 Year Member
Originally Posted by Shelby/Dakota
The way I understand his concept is that he is going to mount plates to the factory engine mounts on the block. Then these plates will mount to the two stands as if it was in the frame of the truck.
OP Please correct me if I am misunderstanding the concept.
That would be exactly what I was planning.
Old Feb 8, 2018 | 05:40 PM
10 Year Member
weld brace in where blue line is. insert a wedge underneath and it brings it up even...
Originally Posted by Angry Johnny
Since the heads of the stands are angled I'm assuming you have plans to straighten them out some how? Otherwise bolting the engine to the stands is not going to work.
regarding above mentioned problem... tell me if you all think this will work. Excuse the crudeness of my drawing, hopefully you get the jist...
unbolted the stand and slid it back until it was level. if I put a wedge under it and a metal brace where the blue line is, think it will work? do it to the other side, and there ya go... even steven right?
Old Feb 8, 2018 | 05:44 PM
10 Year Member
Got it, but how do you then rotate the engine ? front to back, vs longitudinally ? that seems a bit scary to me.
Very interested in this project, either way.
With the outrigger wheels, it will be wider than the motor is long, so no tipping. that's what I'm going for anyway.
Old Feb 8, 2018 | 06:24 PM
Cool. Make sure you develop some sort of safety into those pivots. An emergency brake of sorts, so it can't wizz out of contol as you're rotating it.
Btw......what's ya got under the tarp???
Inquiring minds..?
Old Feb 8, 2018 | 09:31 PM
Jim5870's Avatar
Here is some pictures of an engine stand I made a few years ago, it's rotatable.
Old Feb 9, 2018 | 01:08 AM
edwinsmith's Avatar
That's a lot of weight to hang on those 4 bolts!
Old Feb 9, 2018 | 07:23 AM
deere country's Avatar
The two lifting eyelets on top of the head use less than those 4 bolts. All big diesel engines locate an engine just like that on the stand for rebuild.
Old Feb 9, 2018 | 07:48 AM
That's the first thing I said to myself, but then I did the math, and its only 300 lbs per screw. Shear wouldn't be an issue, just pullout.
I wouldn't set my sleeping bag under it, though
Old Feb 9, 2018 | 10:09 AM
bigragu's Avatar
Can you run the steel perpendicular to your blue line instead? Just thinking with that doughnut isolator compressing on one side it wouldn’t be good.
Old Feb 9, 2018 | 12:38 PM
Jim5870's Avatar
It's steady as a rock!
Old Feb 9, 2018 | 12:57 PM
edwinsmith's Avatar
I don't feel so bad about using 4 x 5/8 bolts on my trailer hitch then. Seems like a high pucker factor to my inexperienced eyes.
Old Feb 9, 2018 | 02:55 PM
10 Year Member
Inquiring minds..?
​​​​​​​Safety device, will do. Under the tarp? 1937 Chrysler Royal that we restoring...
