10W40 For Getrag
Hey guys, thoughts on using AMSOIL 10W40 in a Getrag?
Thanks. |
Originally Posted by GCam
(Post 3349380)
Thanks. Here you go: https://www.genosgarage.com/category...ission-coolers |
Originally Posted by maybe368
(Post 3349384)
Don't do it, IMO. The Getrag g360 uses an oil fling type of oil dispersal and requires 30 weight. There have been some that have put 90 wt and burned out the bearings. The best thing is to add an extra quart for better cooling. I run straight 30 Mobil one and I live in a pretty hot place. I also have 3 extra quarts in it because of cooling fins that bolt to the PTO ports...Mark
I was thinking about throwing on a couple Fast Coolers to add a couple quarts, would you use 5W30 or 10W30, not sure if AMSOIL has straight 30? |
(Post 3349385)
I've been running 5w50 synthetic for last 5 years. No issues.
Originally Posted by u2slow
(Post 3349388)
I run Mobil 1, 5W-30 in my Getrags and have for years.
(Post 3349389)
That may not be such a good idea at 45 degrees...Mark
(Post 3349392)
Why? I figured it would offer the protection/cushioning of a thicker oil most of the time, without getting too thick in the winter (the 5W part). So far so good.
I'd say this 5W50 synth pours very much the same (if not thinner) than dino 10W30 at ambient temps. I overfill too. My Getrags are a long ways from factory bearing tolerances... I figured I'd give the stuff a shot, and its been good to me.
Climate here ranges from about -5°C to low 30's... dunno what that is in F. |
(Post 3349398)
(Post 3349398)
Climate here ranges from about -5°C to low 30's... dunno what that is in F. I am in Northern Alberta, can get as low as -40C and up to low 30's as well, although I do lost of traveling and could end up somewhere with high temps (down south). I was looking at AMSOIL full synthetic 10W40, 10W30 or 5W30. The Getrag is stock as far as I know but I will be adding 2 fast coolers. I normally do minimal towing but am looking at hauling a trailer with a car on it across Canada next month. Just looking for the best overall protection. |
This has all been hashed out, the result is do what you want [laugh]:
https://www.dieseltruckresource.com/...-getrag-53528/ ...Mark |
(Post 3349403)
https://www.dieseltruckresource.com/...-getrag-53528/ ...Mark Perfect haha.. |
Doing some reading the "Synchromax and Synchromesh" products seem to be really good, do you guys have experience with this stuff?
