10W40 For Getrag
Don't do it, IMO. The Getrag g360 uses an oil fling type of oil dispersal and requires 30 weight. There have been some that have put 90 wt and burned out the bearings. The best thing is to add an extra quart for better cooling. I run straight 30 Mobil one and I live in a pretty hot place. I also have 3 extra quarts in it because of cooling fins that bolt to the PTO ports...Mark
Here you go:
https://www.genosgarage.com/category...ission-coolers
Here you go:
GCam (06-11-2018)
I was thinking about throwing on a couple Fast Coolers to add a couple quarts, would you use 5W30 or 10W30, not sure if AMSOIL has straight 30?
I think that the multi vis is ok and now that I think about it, I probably put in multi vis also, the ole' brain isn't as sharp as it used to be I also don't think that synthetic oil is necessary and a straight 30 wt dino oil is ok too ...Mark
mknittle (06-11-2018)
I run Mobil 1, 5W-30 in my Getrags and have for years.
I could be wrong, but I believe the issue is that the thicker oil is not "flung" up to the front main bearing correctly or in the correct amount and the bearing eventually fails. Does it get hot, like 100 plus F. where you live? I am not an expert, but I did stay at a Holiday Inn last night. I did have a getrag grenade on me on my way to Mexico and what I do know about it is from that time, what time is it again? ...Mark
I'd say this 5W50 synth pours very much the same (if not thinner) than dino 10W30 at ambient temps. I overfill too. My Getrags are a long ways from factory bearing tolerances... I figured I'd give the stuff a shot, and its been good to me.
Climate here ranges from about -5°C to low 30's... dunno what that is in F.
I am in Northern Alberta, can get as low as -40C and up to low 30's as well, although I do lost of traveling and could end up somewhere with high temps (down south). I was looking at AMSOIL full synthetic 10W40, 10W30 or 5W30. The Getrag is stock as far as I know but I will be adding 2 fast coolers. I normally do minimal towing but am looking at hauling a trailer with a car on it across Canada next month. Just looking for the best overall protection.
This has all been hashed out, the result is do what you want :
https://www.dieseltruckresource.com/...-getrag-53528/ ...Mark
GCam (06-11-2018)
Perfect haha..
