Mark this thread as Unsold
Engine & Drivetrain Misc 1st Gen parts
Part still available.....
90-93 Electronic gauges, Volt, Temp, Fuel, Oil pressure. All confirmed working. $20ea or $50 for the set.
81-89 gauges, Amp, fuel, oil pressure etc. $5 each
Non-IC upper and lower rad hoses, used...$20 for the pair
Non IC air box to turbo tube...$25
1995 2wd NV4500 tail housing, with hole for speedo cable....$75
1993 fuel tank strap, only one...$15
2wd NV4500 2 piece drive shaft...New u-joints and carrier bearing. Cut and balanced, for a 1984 D350 2wd crewab....$100
1989 1st Gen Cummins AC compressor and engine brackets...$75
D350 Good used, front rotors with Hubs...$50 for the pair.
93 D350 A518 tranny cross member and tranny mount...$75
1st Gen cummins D250/D350 2wd front spindles, splash shields and caliper brackets...$50 for the pair.
1st Gen cummins 2wd lower control arms....$50 for the pair. (Need new bushings and BJ's)
89 Cummins fuel tank. Complete with sending unit. $100
Cummins 12V Fan hub. For 89/90/91 and 94-2002 motors. Just installed a new bearing. $250
1st Gen 4wd Steering box frame adapter plate. Great condition, no cracks. $200
Dave04600
May 29, 2007 06:59 PM
GR40RCapri
Aug 17, 2006 03:03 AM
JD730
Jun 14, 2006 07:37 PM
